Question Help with J&E Rings (cross post from engine building forum)
I received a set of rings from J&E with my pistons.
The top ring set and the middle ring set look exactly the same.
Shouldn't the middle rings be channeled or have a step in it? Like the stock middle rings?
The set was sealed and one package was labeled top, the other ones were stacked together however I see no difference between the top and middle rings.
The set I have is:
JE Pistons Part#: J612U6-3858
Product Type: Ring - Set
Description: 1.5-1.5-3mm RINGSET TOP&2ND TAPER FACE IRON / 1PC OIL
I may have mixed the rings as I was measuring end gaps and cant see any way to tell them apart.
Shane
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 03-11-2010, 10:51 PM
Thumbs up I got the answer:
Answer:
From Troy at EBS: They are the same ring.
From J&E: They are the same ring.
From Charles at LN: same rings.
Just in case anyone else runs into this issue.
Old 03-12-2010, 10:56 AM
