I received a set of rings from J&E with my pistons.
The top ring set and the middle ring set look exactly the same. Shouldn't the middle rings be channeled or have a step in it? Like the stock middle rings? The set was sealed and one package was labeled top, the other ones were stacked together however I see no difference between the top and middle rings. The set I have is: JE Pistons Part#: J612U6-3858 Product Type: Ring - Set Description: 1.5-1.5-3mm RINGSET TOP&2ND TAPER FACE IRON / 1PC OIL I may have mixed the rings as I was measuring end gaps and cant see any way to tell them apart. ![]() Shane
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 03-11-2010 at 10:02 PM.. |
Answer:
From Troy at EBS: They are the same ring. From J&E: They are the same ring. From Charles at LN: same rings. Just in case anyone else runs into this issue. ![]()
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Thread Tools | |
Rate This Thread | |
