Found it, and I have all the symptoms; erratic, wrong or no direction for the turn signals, and intermittent function for the flashers. I bought a Hella, got a good grip on the bad relay but it won't come out with what should be enough force. I don't want to break anything. Should I be worried? Any ideas?
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
"Too much force".
I don't know what to much force might be. I would hold down the relay connecting interface platform (base), and very gently wiggle the relay back and forth. If the relay is on a harness, you should be able to wiggle both sides. Take it slow. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Thanks Gerry. I can only get one hand in. I'll have to try and get someone to maybe hold down the base from the trunk access with something.
I had a brake light switch connector melt and I'm having flash-backs when it wouldn't come off. I had to dig out the broken spade out of the connector; Not fun. I'll keep trying. |
I got at mine from the hood of the car.
+1
East Coast R Gruppe
I was able to pull mine from the front going in through the back of the dash. I am pretty sure I was able to see it from there and reach in and get it out. There was just enough slack in the wire. I believe it was behind the brake fluid reservoir.
Hope that helps.
OGRP3 RGRPNE |
+1
