Question clutch job comming up- anything else while engine is out?
engine & tranny is comming out soon. aside from oil pressure switch, thermostat o-ring, oil cooler seals, is there ANYTHING else to address to avoid future oil leaks? 81'SC
Old 11-30-2001, 05:29 PM
Send a message via AIM to 82SC
change o-rings on engine oil cooler
change gaskets for the oil thermostat and crankcase breather tube
change ALL clutch related parts...DO NOT SKIMP...
do a valve adjustment
MJ
check tech articles of the oil leak fixes...you can email me if you have any question on my article
Old 11-30-2001, 05:42 PM
Jim Smolka's Avatar
Good time for a tranny gear oil change also. Much easier to fill the gear box when it is not in the car.
Also check that the Cam boxes are not leaking and that the oil return tubes are OK.
If you are removing the Flywheel, be sure to order new bolts.
Old 11-30-2001, 05:47 PM
