brads911sc's Avatar
Shift Handle Issue
Ok.. So Im driving the car this weekend. Enjoying the new EFI, 72 degrees, breezy, sunny... and when I go to shift my shift handle rotates. I get home and open it up and this is what I find... with almost no effort I can remove the handle. Here is a pic of the pelican part.... ($261!!!) and you can see on mine that the thing just pulled out.
Anyone else run into this?
JB weld? Replace?
Thanks in advance...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 03-29-2010, 06:55 PM
RedCars
Davewjunior's Avatar
Take it out and weld it. The same thing happened to the PO of my '84 and he just had it welded. This was 7 years ago and it's still holding just fine.
84 911 Cabrio
81 Corvette, 01 Ferrari 360 Modena
94 Dodge Viper R/T10
09 Honda CBR1000RR, 05 Gold Wing
98 Honda Valkyrie ...... All RED ....of course
Old 03-29-2010, 06:59 PM
80-911SC's Avatar
JB should hold it, but welding it would be the preferable method
you could also try a force fit, put it together and then at 6 an 12 strike with cold chisel and mallet to pinch it
Old 03-29-2010, 07:43 PM
Believe it or not this is a sort of common thing. The factory brazes the rod to the lower piece. It is best to weld it together.
I had this happen on a new factory short shift kit. I had just put it in and a couple days later backing the car out of the garage the shaft is just rotating in the lower piece. I took it back apart and welded the tube to the lower piece with a mig welder. That was 6 years ago.
I would not JB weld it. It take quite a bit of rotating force every time you shift.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 03-29-2010, 09:43 PM
cdrik915's Avatar
You could also doing a hole and screwing it no ???
With specials screws like used for the shift rod .
Just an idea.....
LIGHTER = FASTER !!!
Old 03-29-2010, 09:57 PM
brads911sc's Avatar
I like this idea. I cant weld, but I can do this with no issues... Thanks
Just an idea.....
Old 03-30-2010, 04:14 AM
brads911sc's Avatar
Thanks all for your feedback.
boxster03's Avatar
do it right and have it braised somewhere for a few dollars. you can not go wrong with that decision and not to worry again.
Member #750 Early911S Registry
1970 911E
I know Where Jerry S. has his NYC Garage
Yadda Yadda Yadda
Old 03-30-2010, 06:11 AM
