rpm problem
Here you have my rpm problem: when I drive the rpm is going well up but when I put gear to neutral rpm stop on 2500 -1500 rpm even if I stop the car. I found that if I engage softly and for short second a second gear (or third ...) and than disengage to neutral again I have 950 rpm like it should be. So it is frustrating to have to high rpm on neutral and it is difficult to engage first gear in 901 gearbox this case. What it could be, linkage on Weber's or anything else?
TET930 996 TT 2003 X50 996 GT3 2004 930 1988 black on black -fast... 944 TURBO S 1989 WHITE/BLACK # 1 944 TURBO S 1989 #2 911 S 1970 Targa /ex porsche werks car! 911 S 1969 Targa (under rebuild) |
Check your linkages. From the engine compartment, manually move the accelerator connection to increase rpm and release. If the rpm's stay high after release, try pushing on the connector to see if the linkage reseats.
You might also check you distributor advance to see if it "snaps" back easily.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
muck-raker
I'm not quite sure if I understand the problem, but maybe your throttle linkage is stickng?
I think this is G50 specific...when the weather warms, the portion of the throttle linkage which attaches on the driver's side of the tranny will get sticky in warm weather. Clean and lube the linkage and the bearing which mounts on the tranny.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Max Sluiter
My 1971 911 had that same problem prior to servicing.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
In my view the gearbox has nothing to do with the engine RPM when disengaged.
I had the same problem with my 72. It was a sticking flapper box (not on a 71 though). Oiled the accelerator linkage and all fine now. Good luck. Ed |
the push rod system can easly get stuck. Im +1 for cleaning and lubricating.
Pete Porsche, there is no substitute! 911 Coupe 1974 plus bits | Stuttgart eXchange | Channel P101tv |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
I think you may have an interference issue with your throttle linkage and shift linkage(s) inside the tunnel. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
