Vaccinated and Boosted
With Headlights on, Turn signals do not work! WTF?
So I replaced my turn signal lever assy and installed a headlight relay system. All parts from Pelican, and now my turn signals do not work when I have the headlights on!!! I have looked at the wiring diagram here but not sure I am smart enough to understand this.
Any suggestions?? Oh, this is on an 83 SC Thanks!! mg
2013 911 Turbo S 2025 Lexus TX350, 2024 Honda CRV Hybrid 1930 Cadillac V8, 1991 Ford F250, 2023 Chevy Colorado And some garage space.... |
Forced Induction Junkie
mg,
Does the turn signal light or indicator come on and not "blink" or do they not light up at all? First place I would look would be all the grounds up front where they ground to chassis and at the rear grounding of housings to chassis. Start from the front first.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
With the headlights off, they work perfectly. With the lights on high or low beam, nothing! No blinking no indicators on, nothing!
Thanks all! mg
Senior Advisor
check where you installed the headlight relay, might be touching another fuze. Better yet, try disconnecting the headlight relay and see if that fixes the problem.
08 Cayenne Turbo |
