Can you add a Turbo to a 3.0 SC Motor??
Is it possible to put a Turbo onto a 3.0 SC motor and what all is required in doing so? Has anyone done this?
THanks, James |
Yes.
Many ways to go from a custom with existing injection, using 930 take off system, or custom EFI based system. HP could be from 270 to 700. See this: Help me design a "grassroots" turbo conversion for my SC 3.0L |
Sorry i didnt give much details. I have a 1983 911sc Complete Turbo look and want to gain more horsepower without completely going broke! I already have custom heat exchangers, cats removed, bursch exhaust, k&n, so is there a way to bolt on a turbo without much labor?
Probably easyer and cheaper to sell your motor and buy a used 930 motor.
However, see the link above I think your goals might be the same. |
Dog-faced pony soldier
You can turbocharge a lawnmower if you want (and yes, it's been done). The questions are how expensive and how reliable will it be.
With enough time and money, you can do anything.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
1980 911 SC
Would anything need to be done to the pistons, rods, crank, bearings etc. ? To accommodate the higher horspower ?
Life's a Beach |
There is, however, no "cheap" solution to this unless you can pick up someone's complete project for pennies on the dollar.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
As many have said, yes it can be done and has been done. I am just about to convert my 78 3.0 with a M&K kit which I plan to document here in the next month.
Feel free to email if you have any questions.
Jeremy C. Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham) ----Nothing is far away in this car!--- -2001 996 Turbo |
Can you trust yourself not to exceed 5 lbs. boost? With careful attention to details as suggested by sjf911, it should be fine. However, should you be tempted to inject more power by turning up the boost, expect shorter component life (rings, pistons, head sealing).
Sherwood |
TRy Tony at Tbitz racing in Ottawa I believe he has done it. He also supplies an EFI kit.
Richard.
Life is not a journey to the grave with a pretty and well preserved body but to skid in sideways, used and worn out saying " What a trip! |
Gary R. |
3 restos WIP = psycho
There are numerous conversion threads on the Pelican turno forum. Check it out.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
1997 C4S stock...ish 1970 911T Restored Hot Rod....Sold ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html |
Search my name tons of threads regarding all of my conversion process and approx costs. I don't have a link at the moment
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
A good start:
my 3.2 ss/twin plug/turbo motor Good pics: SSI turbo exhaust FS 930/turbo conversion turbo conversion exhaust 993 heat exchanger based
