SC Front Torsion Bar Failure
My left front torsion bar failed yesterday (tow home). My car is stock, but the fender dropped onto tire and scrapped the outer edge. If this had happened at speed I would probably be dead now.
It seems the right stock (19mm) torsion bars are NLA and I’d like to change both. Has anyone used a left bar on the right side? Does anyone have a technical answer as to why there are left and right bars and why they might not be interchangeable?
Also, I have Bilstein struts in front (installed by PO) but they have no bump stops. Bump stops should prevent the front from dropping onto the wheel. Do Bilsteins normally come without stops? The parts diagrams show that Boges do have bump stops.
Old 04-24-2010, 12:47 PM
Tired Member
DaddyGlenn's Avatar
The twisting force on the left is applied in the opposite direction from the twisting force on the right. Check the used parts for sale board...
Porsche 911 Used Parts For Sale & Wanted - Pelican Parts Technical BBS
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 04-24-2010, 01:35 PM
Senior Advisor
James Brown's Avatar
If your talking about the steering bump stop than that would not helped. You should replace both torsion bars as a set. and they are not interchangeable, there is a right and a left, don't mix them up.
08 Cayenne Turbo
Old 04-24-2010, 01:46 PM
Max Sluiter
Flieger's Avatar
If the bar is new, you can use it on either side. Once it has been twisted for a while during driving, it is a good idea to keep it on the same side because the metal's internal structure will have become a little deformed / strained / work-hardened so stressing it the other direction may cause a brittle failure.
I love 2 different answers. It really makes your head spin. I believe that the left and right are different, and not the same. This would be true with all vehicles which use torsion bars, at least american trucks anyway. I guess getting 2 new ones would be wise. I probably wouldn't, but I am thrifty
Old 04-24-2010, 01:55 PM
AutoBahned
RWebb's Avatar
AFAIK, the markings are not imp. until after the bars have been used.
Old 04-24-2010, 02:48 PM
Thanks for the answers.
Old 04-25-2010, 11:29 AM
Regis turd ab user
FS Torsion bars, 19mm and 23mm
Old 04-25-2010, 11:50 AM
Bland
unclebilly's Avatar
I have a set. $50 + shipping. PM if you want them.
Old 04-25-2010, 02:52 PM
