Bilstein Front Strut Bumpstop Question
This week I replaced my front Bilstein shock inserts. When I took the old inserts out, I found NO rubber bumpstops on the rods of the shocks. This car, an '80SC came from the factory with Bilsteins all around. I bought the car in '83 from a South Texas ranchers wife, who bought it new, and I don't think anything was ever done between new and my purchase. Question is, why no bump stops?
When I turned the empty struts upside down, the only thing that fell out was a convex washer that I assume was meant to guide the shaft into the hole in the bottom of the strut. The car also had the big 10mm washers on top of the strut, which I left out on reinstall. I also used the 3 section rubber bump stops that came with the inserts. I plan on running a Euro front height of 25.5". Was I correct to install all 3 sections of the bumpstop assy? Also any ideas why they had no bumpstops from the factory?
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 04-29-2010, 03:42 PM
Senior Advisor
James Brown's Avatar
That 'spacer' was placed there, if original, by the factory for U.S. spec. cars. Someone might have removed it in an attempt to lower it to Euro specs. It's ok if it is not there.
08 Cayenne Turbo
Old 04-29-2010, 08:18 PM
I know why the 10mm spacers were there, that's why I left them out. My question is why it came from the factory with the rubber bumpstops missing!
Old 04-29-2010, 09:04 PM
Senior Advisor
it was Friday? (at the factory) if your going to lower it than you need to remove those spacers.
08 Cayenne Turbo
Old 04-30-2010, 12:00 AM
New Bilsteins have the bump stops internal. I don't know about that era.
Scott Wilburn
1988 911 Carrera 3.4 L
1998 M3
1984 308 QV
Old 04-30-2010, 12:44 PM
New Bilsteins for Boge struts have internal bumpstops. New inserts for Bilstein struts still have external rubber bumpstops. Just got a new set of Bilstein inserts for Bilstein struts, and came with a set of three section bumpstops!
Old 04-30-2010, 01:42 PM
Thanks for the correction.
Scott Wilburn
1998 M3
1984 308 QV
Old 04-30-2010, 02:48 PM
Check on the Elephant racing site they show you which portion of the bumpers to cut off when lowering.
Lorne M.
83 SC
Old 04-30-2010, 07:45 PM
MikeD930's Avatar
Lorne M.
Hmm, I could not find it at Elephant Racing. Can you explain where you found this info? I'm about ready to put together the front end. Thanks.
MikeD '87 930
Old 05-01-2010, 06:50 AM
It's not Elephant, it's on Smart Racing Products (SRP).
http://www.smartracingproducts.com/pdfdocs/bilstein_rubbershock_front.pdf
Old 05-01-2010, 07:16 AM
MikeD930's Avatar
Thanks for the link!
MikeD '87 930
Old 05-01-2010, 07:25 AM
Sorry old timer disease kicked in , yes It is Smartracing.
Lorne M.
83 SC
Old 05-01-2010, 11:14 AM
