86 wiring help
My windows wouldn't work yesterday. I traced it down to no power to the fuse (first one on the fuse block nearest the rear of the car). I can put power to that point and they work fine.
My wiring diagram says that black wire comes from the "power window control unit".. Anyone know where that unit is ? Looks like a relay box in the diagram
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
This came up before - seems the relay got moved between 86 and 87 - not sure but I think it may be behind the tachometer. My Bentley wasn't clear. I see the schematic reference to the PWCU, but it doesn't give the location or even list it. It does call out the Power Widow relay twice based on year.
As I mentioned, it came up before because someone else had an issue with an 86 and it was setup like an 87 - a little confusing. Maybe Gerry will chime in.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Todd, Here's what I think. The power window control unit and the power window relay are the same component, as there is only one relay in the CKT. Many times when a relay contains any solid state devices, it is designated a "control unit" Additionally, fuse #1 get's the +12V from the relay. I would be looking for +12V @ pins 7 & 2. Pin #7 most probably feeds the CKT, and pin #2 is on the relay armature/contact which feeds the window switches. Check all of the above prior to purchasing a new relay, as too often, P-car owners buy non-refundable unneeded electrical parts. There is one on eBay. Item #270368115573 ![]() Here is the location of the power window relay. ![]() If all of the above fails, pm me. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 05-01-2010 at 04:42 PM.. |
