Whats the guidelines for getting a valve adjustment?
What are the general guides? Mileage? Time? Noise? Type of usage? My 89 hasn't had the valves adjusted for 5-6000 miles and maybe 3 years. I don't notice any problem, but am wondering if I should have them do it at the next inspection. It's not like I want to hand the garage $300 for nothing. When do you determine its time to adjust them?
You can do it yourself for less than half that, including oil and a filter. Now that the weather is good, you should do it now.
I believe 15000 miles is recommended to check clearance.
Is there a guide for this somewhere?
1984 Carrera 3.2L Coupe, Guards Red |
No sleep 'til... BROOKLYN
THe Bentley and Wayne's 101 books explain the procedure, if you do a search on the subject you'll find countless threads about it. Take care.
-Orlando- '89 3.2L G-50 '77 S w '79, 3.0L '90 T-3 Syncro 32C #16 |
Being that I bought the car 11 years ago and put 30,000 miles on it, it would be a lengthy time between adjustments. If the car sits for lengths of time, is there a time factor? Thanks also for the DIY suggestion, but those days are long gone. As far as a guide, I meant when it should be considered, not how the procedure is done. I have helped doing them a few times but would rather have it done at the garage.
Tired Member
If you're not running the car, there is nothing to change the adjustment. I do my valve adjustments every third oil change interval, every 9,000 miles.
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
Time factor is not specified in the Bentley, just mileage, 15K miles is recommended. Quote:
I was answering laundromatt's question.
Recreational User
The guideline is every 15,000 miles, period. It's in your car's maintenance manual.
