view of gauges/Prototipo
Anyone have a pic of their Prototipo and gauges? Thinking about getting one and curious about the view thru it.
Paul
'87 Carrera cab; '19 Ford Flex for the Dane and Lab; '17 Tacoma for truck stuff.
'96 993 cab (gone, oops); '82 SC (gone)
Old 05-02-2010, 05:17 PM
That would be for the SC of course.
Paul
Old 05-02-2010, 05:21 PM
zugelassener benutzer
teamfee3's Avatar
you won't see much.
Team Fee '86 Carrera 3.2 Coupe blk/blk, no wing
7&9x16s BFG GForce SS 205/55 & 245/50s, SW Chip, Maxspeed catbypass, B&B, Sachs Power Clutch, Turbo mounts, oil cooler scoop, RS door panels, Momo Prototipo, Rennline fully adj gas pedal & floorboard, RS replica dead pedal, Weltmeister yellow h/l lenses, factory short shift, custom speedo
32C #7
Old 05-02-2010, 05:32 PM
sudo apt-get purge 930
equality72521's Avatar
If you rotate the gauges left about 22° you will see everything important.
--clutch-monkey
Old 05-02-2010, 05:55 PM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
Or you can do what I did....send speedo to North Hollywood Speedometer and have them reface your gauge to remove the KPH numbers and rotate the numbers and re-index your needle so it looks normal instead of sideways when you read it.
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 05-02-2010, 06:39 PM
Don Booth
70 911 T Coupe
74 914
Old 05-02-2010, 06:41 PM
brads911sc's Avatar
You cant see anything through it on my SC. Its annoying but i love the wheel... and besides if you cant see 60-90 then you can really tell the officer you didnt know how fast you were going
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 05-02-2010, 06:42 PM
Don, that looks good but it's cheaper to just turn the gauges
--clutch-monkey
Old 05-02-2010, 06:43 PM
Cool MOMO 370mm Prototipo
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 05-02-2010, 08:13 PM
Stock steering wheel is cheaper than a Prototipo too....
Don Booth
70 911 T Coupe
74 914
Old 05-02-2010, 08:21 PM
Bring them to North Hollywood and have them to this to the gauges. Looks a lot better than
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 05-02-2010, 08:26 PM
kugelfischer's Avatar
Depends on your angle of view also. If you are tall and looking down on the gauges you will have quite a bit cut off from view. I'm 6'1" and can't see anything on the speedo from 30-90mph. (with the standard 350mm Prototipo). Love the wheel, hate the view.
Old 05-02-2010, 09:22 PM
I know this may be a little off topic, but It goes with the theme of the thread. Is there any noticeable difference in the steering between a 350mm wheel and stock in regard to steering feel/response? I just got a momo mod 69 and have yet to put it on due to maintenance currently being done on the car, but am considering the possibly of a sparco 678 wheel (380mm).
Just wondering if il'll regret the 350mm vs 380mm (little over an inch difference).
Old 05-02-2010, 10:25 PM
skinnerd's Avatar
Some people like the smaller 350mm steering wheels, but they do block some of your vision of your gauges.
I tend to like the larger steering wheels (380-390mm) for a couple reasons.
One of them being an unobstructed view of my gauges, another being greater ease in turning the steering wheel.
At least for me.
To each his own.
For most things in life.....there are tradeoffs.
Luckily most steering wheels don't cost all that much, so it is easy to try a couple of different sizes to you arrive at the one that works best for you.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 05-03-2010, 02:09 AM
