face-ache's Avatar
whos opened up an air volume sensor?
I have a quick ? there is a 'u' shaped copper contact with two sep contact spots which swings around with the barn door. Is this in contact with the board surface at all times or does it warm up like a thermostat then touch to make contact?
mine is not quite touching and want to make sure b4 I put it back together..
Thanks!
Dave
David.
85 carrera euro
Old 05-06-2010, 04:30 PM
steely's Avatar
I haven't yet, but there is some info found here from others.
You can check this site out as well.
The wiper should be making contact with the trace, this site addresses how to adjust to a new arc on the trace - info may help you address your situation.
Air Flow Meter (AFM) - from "The 944 Motronic DME" by FR Wilk
try the battery test to evaluate yours.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 05-06-2010, 06:10 PM
face-ache's Avatar
Thx Dan, excellent info!
David.
85 carrera euro
Old 05-06-2010, 07:43 PM
Ruby911
ruby911's Avatar
I had mine apart and as I recall it should touch at all times. Verify that the contact point point of the sweep has good material throughout the range (mine did not and is why I had it open). As stated above, there a e a couple of very good detailed threads on this topic.
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD
1968 Ossi Blue 912 Sunroof Coupe - SOLD
1971 911E - 2.7 Twin Plugged, PMOs - SOLD
1965 356C Outlaw
RGruppe #577
Old 05-07-2010, 06:08 AM
