wipers will not return to park position
Windshield wipers will not go to park posision when shutoff they stop where there at . 1981 porsche 911 targa. Not sure where problem is . help thank you.
Old 05-18-2010, 10:14 AM
muck-raker
kidrock's Avatar
do you have a separate intermittent button or switch for your wipers? What happens when you jiggle your wiper stalk?
Chances are, one or both of these switches are old and/or dirty. I recently had a similar problem. I replaced the wiper stalk, and everything now works perfectly.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 05-18-2010, 10:42 AM
Does the intermittant function work? If not, could be a bad intermittant relay, as it is used to return the wipers to park when they are shut off.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 05-18-2010, 10:50 AM
jsmithcds's Avatar
wiper park
Pull the assembly off the column (leaving all wires attached) and check all the contacts inside. One of the small contact tabs inside has likely lost its rigidness. I should have taken pictures but basically pull it out and use a small screw driver to bend the tabs back until they make contact while in the park position.
It solved my problem. You would need to take it apart to replace anyway. Just take your time and fiddle with it. It may save you $100 dollars in parts.
79sc Flared with a 3.2SS conversion 9.5:1 J&E's with 964 cams and M&K exhaust
Viper Green
He who laughs, lasts.
Old 05-18-2010, 11:56 AM
Senior Advisor
James Brown's Avatar
yeah try to push forward on the wiper stalk, if they park, then do what jsmithcds says. Most likely the intermittent wipers don't work also.
08 Cayenne Turbo
Old 05-18-2010, 12:01 PM
