Can someone tell me if this oil line can be rebuilt
I have a 1968 2.0L engine. My understanding is that the OEM line has been replaced with a hose. I want to rebuild this oil line that goes under the transmission and connects to the oil tank. The OEM part number is 90110733112. Where can I buy the hose and fittings. This looks like a pretty easy job.
Item 18 on the diagram.
Old 06-22-2017, 04:12 PM
Discseven's Avatar
DS... Hydraulic place would have end-fittings and hose. Am not familiar with that connection between the hose end-fitting and hard line. I'd bring entire length and tell hydraulic place to solve puzzle. Need oil & high temp hose as opposed to any hose.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 06-22-2017, 05:19 PM
You can bring all of them to a local hydraulic shop so they can see it. Most likely, they will only rebuild the rubber hose part and crimped fitting The metal tubing and compression fitting is reusable by design.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 06-22-2017, 05:34 PM
French Import
zippy_gg's Avatar
Try Elephant Racing
The page specifies model year 72 and up, but you can call them.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 06-22-2017, 05:40 PM
Try Len Cummings aka boxterGT here on pelican. He's your best bet, all the hydraulic shops I visited when in need of repairs just had stupid looks on their faces when I told them the lines were from a Porsche.
Old 06-22-2017, 07:11 PM
I went to three hydraulic hose shops and they all where clueless. How can I get a hold of Len Cummings aka boxterGT? Can I send him a PM?
Old 06-22-2017, 09:45 PM
Thanks for the info zippy_gg. I'll give them a call in the morning.
Old 06-22-2017, 09:48 PM
proporsche's Avatar
I have been using for most of my Porsche live these guys ...excellent work
Orme Brothers Inc. Performance Hose and Fittings
Ivan
Old 06-22-2017, 11:54 PM
[/http://www.autosportengineering.com/
Old 06-23-2017, 12:14 AM
All you need is the exact size hose and them it just screws together. The exact size metric hose is the issue.
206 637 4071
Old 06-23-2017, 06:26 AM
72911's Avatar
I've been dealing with Len Cummings for about two months now and he is not your best bet. Parts Klassic has a custom metric hose service.
72 2.7 Driven!
Old 06-23-2017, 07:20 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Belmetric has high quality OEM-like Cohline hose
https://www.belmetric.com/metric-hoses-c-14.html
Kevin L
'86 Carrera "Larry"
Old 06-23-2017, 07:45 AM
Your oil lines have reusable aluminum fittings made by TechnoChemie (TCh). They can be rebuilt. The hose is DN16 hose (18mmID x 25,5 OD) made by Cohline. I only make the larger, DN20 hose (22mmID x 30.5mm OD) fittings used in '70-'71, but you can contact Brad Davis at HBD Products & he can set you up with both the small fittings and the hose that you need.
Old 06-23-2017, 08:35 AM
Under the radar
Trackrash's Avatar
I just used AN-16 stainless braided. Older cars may need -12 hose.
Gordon
'71 911 Coupe 3,0L outlawed
Old 06-23-2017, 09:28 AM
Thanks for all of your help !!! I found all the parts needed at parts Klassik I will post a picture of the whole assembly when I get the parts next week. Have a great weekend.
Old 06-23-2017, 12:03 PM
I did look into the AN-16 and AN-12 stainless braided lines. The ID and OD wouldn't work with my parts.
Old 06-23-2017, 12:39 PM
Old 06-25-2017, 07:31 AM
Under the radar
Trackrash's Avatar
FWIW, I used AN 12 to replace the hose from the engine to the tank on my '71. Had the OE hose wear through. No problems for decades with the AN stainless.
Perhaps the '68 is a different size.
Gordon
Old 06-25-2017, 09:03 AM
Thanks again for everyone's help. I was able to fit a new hose end to my existing line.
Old 06-28-2017, 11:17 AM
