Carrera 3.2 engine won't stop after switching off
The engine starts without problem, runs fine, but will not stop after the ignition switch was turned off. I disconnected the wire connector from the electrical part of the ignition switch but the engine continued running. The problem was intermittent and in one instance the engine suddenly stopped when I happened to turn off the fan switch of A/C in the central console.
Any advice? Thanks!
'87 3.2 Targa |
Swap out the relay for the AC and see if it goes away.
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
Thanks! The AC has been removed long ago but I'll check if there is any residual circuit left.
Please follow this problem on another same-titled thread as this one was incidentally duplicated.
'87 3.2 Targa |
