pcar9119's Avatar
RSR rear bumper backdate problem
I'm installing a early RSR bumper on my SC. I have all the things removed and out of they way to fit the bumper into location, but I have a problem. The bumper doesn't line up with the fenders. It seems to be too long or something. Here is some pics of the bumper partially installed on the car. I don't know if I'm missing something, or I need to seriously mod the bumper or need a new bumper. Please help. Thanks.
Old 05-23-2010, 04:58 PM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
Looks like the bumper is for 11" flares you have what appear to be 9" Turbo flares.
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 05-23-2010, 05:57 PM
skinnerd's Avatar
Exactly....your bumper is for larger RSR or turbo flares.
You need an RS rear bumper.....not RSR.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 05-23-2010, 08:12 PM
pcar9119's Avatar
My car has the turbo flares. Thats why I can't figure out what the problem is. Are RSR rear flares wider than turbo flares? I thought they were the same...
Old 05-23-2010, 10:42 PM
pcar9119's Avatar
I've seen theses setups with 3 pieces. Do they have wider outside to fit turbo flares?
Old 05-23-2010, 10:47 PM
Max Sluiter
Flieger's Avatar
There are RS 2.7 flares (8inch flares):
RSR 2.8/ RS 3.0 flares (11inch flares):
and RSR 3.0 flares (14 inch flares with the vents):
Flares are rated by the wheel size they can fit within. Sometimes camber and alignment can squeeze more wheel and tire into smaller flares.
Old 05-24-2010, 12:11 AM
Max Sluiter
Flieger's Avatar
RS are similar sixe to your Turbo flares:
RS:
RS:
RSR 3.0:
Old 05-24-2010, 12:14 AM
pcar9119's Avatar
So, what you are saying, that I seem to. Have bought RSR 3.0 flares and not the RSR that I would require. Nice. Hmmm, should I, could I modify this bumper to work. You know, a little cut and paste. Great pics by the way, now it makes sense...
Old 05-24-2010, 12:25 AM
skinnerd's Avatar
Also depends on how the flares were attached.
Usually, the flares and bumper are installed together, such that "minor" adjustments can be made to make the flares and bumper line up correctly.
Yours appear to need more than "minor" adjustments.
Turbo flares and 73 2.8 RSR flares are basically the same width....excepting some differences in the profile.
74 3.0 RSR flares are substantially wider.
Your flares do look like turbo flares.
So if the bumper you have is too wide (which certainly looks the case)....you should look for a better fitting "true" RSR bumper.
Your bumper looks like a lemming....oddball part.
The rear bumper for the wider 74 3.0 RSR looks completely different.
Doug
Old 05-24-2010, 01:46 AM
benp911's Avatar
I have 11" RSR flares which are 930 turbo size, perhaps your bumper is for a 14"RSR.
I bought all of my parts from rennspeed. My flares look like yours.
Old 05-24-2010, 09:28 AM
benp911's Avatar
you just need a new rear bumper.
Old 05-24-2010, 09:30 AM
benp911's Avatar
RS:
RS:
RSR 3.0:
The first and second pic show 9" front and 11" rear also the pic with three cars shows the 9 and 11 flares. I am backdating my 78 sc right now and it goes in for final paint today.
Old 05-24-2010, 09:34 AM
Max Sluiter
Flieger's Avatar
Yes, the RS 3.0 had wider flares than the Carrera RS 2.7. It used the 2.8 RSR width flares with 9 and 11 inch wheels. The RSR 3.0 had the 14 inch rear wheels with yet wider flares with vents.
I think the OP has the RSR 3.0 bumper but Turbo flares (width of RS 3.0)
Old 05-24-2010, 02:51 PM
pcar9119's Avatar
It sound like I'm screwed. Damnit. Guess I need a new bumper, anyone have one?
Old 05-24-2010, 03:21 PM
benp911's Avatar
I think my rear bumper was $250 or $300 from rennspeed.
Old 05-24-2010, 04:11 PM
Zeke's Avatar
When you get the smaller bumper, it will likely need some fitting. If it were me, considering selling what you have, shipping, buying a new one, shipping, fitting and all else, I'd start cutting on that one.
Fiberglass is easy to cut and mend. There are a lot of treatises here and on many other forums. PM me for any specific advice. --Milt
Old 05-24-2010, 04:24 PM
