pmajka's Avatar
Engine tapping noise when hot
I did a search and read threads.
Just had a valve adjustment done.
when engine is cold, it sounds nice and tight.
when engine is at operating temp, i have a tap on left side. cant really hear it in engine bay, but prominent at left rear wheel.
when i get the engine really hot, 220F (like coming off track) I believe its louder.
engine has 60Kmiles on rebuild, using Mobile 1 15/40. pulls strong.
Others think its fine, i find it annoying and wondering if i should have a concern.
88 911, andial 3.7L with c2 cams.
Have you ever felt suffocated while watching the Oxygen Channel?
People with excuses fail. As soon as I OK my actions with an excuse, I cease bettering myself.
88 Carrera
Old 05-24-2010, 07:01 AM
pmajka's Avatar
Acoustically speaking, i pulled into a BK drive up window, brick wall with roof. I had to turn motor off to hear attendant. I could hear tapping over exhaust noise.
B&B 1.75 headers and B&B 2 in 1 out muffler
88 Carrera
Old 05-24-2010, 07:04 AM
muck-raker
kidrock's Avatar
the tapping noise could be a small number of things, but I believe you will find a loose valve tappet...it happens. Readjust the valves.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 05-24-2010, 07:22 AM
Taking it apart is easy
Jerome74911S's Avatar
Mine taps when cold, then quiets down as it warms up. . .
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 05-24-2010, 07:43 AM
Assuming there was no tapping before the adjustment,
is it possible you just found the answer to your problem?
Cheers,
Joe
Old 05-24-2010, 07:53 AM
dshepp806's Avatar
+1> Maybe they have one that's not quite where it should be.
It WILL have to be checked again.
I've found that any tappet noises will increase with temp (not decrease).
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-24-2010, 12:14 PM
When the engine is cold, the oil is thick enough to mask the sound of a loose tappet until it thins out with heat.
Old 05-24-2010, 01:05 PM
exact same situation on my car when I bought it... turned out to be worn valve guides. DIY and $6k later was all fixed up. :-) I had a case of "while you are in there". I used the Wayne book.
Old 05-24-2010, 01:40 PM
Senior Advisor
James Brown's Avatar
Holy cow, let's start with checking the valve lash first!! One problem is you check it cold. Did you do the work? Use a stethoscope to pinpoint where the noise is coming from (hot). then go from there.
08 Cayenne Turbo
Old 05-24-2010, 02:28 PM
pmajka's Avatar
had it done by a Mech.....
should it be done cold, warm, hot?
88 Carrera
Old 05-24-2010, 08:24 PM
bgyglfr's Avatar
Valves have to adjusted when the motor is stone cold. It is best if you let it sit overnight before adjusting the valves. Guys, correct me if I am wrong. I had an early car that was tapping and the tensioners/chains were loose.
Kirk
70T 2.7RS spec.
68L coupe
Old 05-24-2010, 08:39 PM
enjefriy's Avatar
Sounds similar to mine. Left bank as well.
Very apparent when cold, goes when warmed up.
Valves are only to be set when engine is stone cold.
Is my understanding correct as below;
the specified gap is given inorder to allow for thermal growth once the engine gets to working temp.
So if the tapping noise gets lesser with a warmed engine, the gap has been closed up by the expansion.
If the Tapping noise doesn't reduce, the gap may have been set too large.
But if the tapping noise get louder with a warmed engine, this indicates a mechanical problem instead.
Lastly, if there isn't any tapping noise whatsoever (hydraulic tappets aside), there is a chance that too little or no gap has been set, and this could lead to the valves not fully seating & closing, and eventually excessive wear introduced to the rockers, tappets etc.
Old 05-24-2010, 09:17 PM
initial's Avatar
My 89 did the same when I purchased it a few years ago. Driving beside a brick wall or even the curb was quite disturbing.
It would be quiet when cold and get progressively louder when it warmed up.
It all quieted down after I adjusted the valves. I now hear tic-tic-tic instead of tap-tap-tap.
If you adjust the valves, do use wd40 to get the oil film out of the elephant foot. I believe this makes a big difference in being able to set the valve to the proper gap.
95 Carrera 4 Black/Black Coupe, Row M030, Bilstein HD
Past - 89 911 3.2 silver cab
Old 05-25-2010, 05:09 AM
ratpiper71T's Avatar
Have you checked for a possible exhaust leak?
Old 05-25-2010, 05:59 AM
Senior Advisor
Yes, Yes, Yes. thermal expansion will close up the gap a bit when it gets warm. Set the valves cold. Most 911's sound like a bag of parts in the back of a pick-up truck when idling around town. If you engine sounds good at idle and at 4-5k than I think your fine. I use to freak out when I drove downtown among the big buildings, sounds like I was running on 5 cylinders and the heat exchangers fell off. But back home everything was fine. Just another Porsche quirk.
However, non normal valve lash sound should be investigated prior further operation.
You can use a mechanics stethoscope or a long screwdriver placed in your ear.
08 Cayenne Turbo
Old 05-26-2010, 10:51 AM
after letting my car sit overnight, I turn the engine over (via crank pulley) 2 times. This seems to set the spring tension equally. If you still have problems, tighten down the adjustment screw to squeeze out any oil and keep the feeler gauge kleen.
Old 05-27-2010, 04:17 AM
red 2.7's Avatar
I think that using a feeler gage is not the best way with "feel" too much a factor. If your mechanic can use a dial indicator instead you will get a better result.
Wally in Montreal, Canada
My age 50 something,P- Car's age 30 something 2.7 911S PMO 40's , E cams, RS pistons/cylinders, MSD6AL, Pertronix, SSI's, M+K 2 in 2 out. Perfect studs (whew!)
Old 05-27-2010, 05:37 AM
