running lights 86 911
Right side running lights wont work.. All the other lights work just the right side runners thanks for the help,
Bob: |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
It's located adjacent to the light switch on a very small PC board. Note: This diode was only used on the '86 3.2 cars. Starting in '87, an updated light switch was introduced, (-03), with one additional contact. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 06-16-2010 at 12:54 AM.. |
On the 86, there is a diode in the circuit. It is usually under the knee rest just below the ignition key, or jut to the left of it. It's in a white/clear square case, similar to a fuse holder.
kb mercedes GLK350 2009 boxster s 86 targa |
Member 911 Anonymous
Make sure the bulb's contact is not corroded, mine was and after cleaning it worked fine.
I discovered this because I thought bulb was out but when I started to remove it with the running lights on, it came on when I put it back it went out. I proceeded to clean it, Voila no more issue.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
