Valve Adjust Issue - Can't turn engine with the fan belt
On my last attempt to adjust my valves I ran into an issue that I was unable to overcome. Even with the plugs removed I was unable to turn the engine over using the fan. I installed a new belt and tried to shim the pulley as tight as I could get it but eventually the fan blades started to rub on the bottom of the fan housing, even with the belt that tight I couldn't turn the engine. I also tried pinching the belt between the pulleys but that didn't work.
Is there any other way to reliably turn the engine when doing a valve adjustment? |
Senior Advisor
A remote starter switch or bumping the car in gear. How long has the car been sitting? You say "last attempt" to adjust the valves, what happened with the first attempt? Can you turn the engine over with the starter and the plugs removed?
08 Cayenne Turbo |
Box wrench on crank pulley. Got enough room?
I connect a remote starter switch on the starter solenoid, then jog the engine to position the valve to adjust. Sherwood |
If your fan is moving in the housing (fan binding on outer housing) then the alternator/fan is probably coming loose and has to be tightened to the housing. To do this you have to remove the strap that holds the whole assembly in place, pull the fan assembly out and you might be able to tighten the 5 or 6 nuts that hold the unit together while the wires are connected. If not disconnect your battery label the wires and remove them. Then take the whole assembly to your workbench.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 06-15-2010 at 10:06 AM.. |
you don't actually pinch the belt, you push in the the right side firmly, between top and bottom pulleys, as you turn the pulley nut clockwise, a little at a time. takes a bit more effort as each cylinder comes up on compression. even works with a loose belt.
Doubtful. The car is a 930 and that area is cramped. Quote:
Southern Class & Sass
Did you put the car in neutural first?
Dixie Bradenton, FL 2013 Camaro ZL1 Last edited by Dixie; 06-15-2010 at 10:30 AM.. |
Remove the belt and spin the fan. Does it spin freely? Wiggle the fan in the housing it shouldn't move. If it does then the mounting nuts are probably coming loose. If it is all tight then its something else. Try a can of spinach.
![]() Shane
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Check the friction surface of the drive belt. If it was loose for some time, it might be glazed (shiny) in which case it'll be more prone to slip. Something else to check.
Sherwood |
Plugs out - put in 3rd or 4th gear and gently roll car forward.
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
maybe wrong direction?
hard to believe with the plugs out that you cant turn the engine. Are you turning it clockwise?
1975 911S Targa Silver Anniversary Edition |
Good question. I really hope I did but time has passed so I can't say for sure. I was doing this on my steep driveway with the rear tires on ramps so I may have not have remembered to pop it into neutral. How embarrassing if that is the case.
The fan does turn freely without the belt in place. There is a little play in the fan but it seems to be the armature moving and not the alternator itself. I will check it all out tonight (with it in neutral) and report back. |
Mine has always been the same way. Fan belt would just slip. I use a wrench on the bottom pully / crank shaft. Make sure you are in nutral ;-)
Chris 73 911 E |
Senior Advisor
If it's in gear I would not admit it!!! Make up some story like a family of chipmunks moved into #3 cylinder and you had to coax them out with peanuts!! Save your manhood!
08 Cayenne Turbo |
Formerly known as Syzygy
Hey could possibly have the best one in the Dumba55 moves post...
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
sudo apt-get purge 930
I had the same problem for about 2 minutes... then I realized the car was in gear. You aren't alone if that's it. I just didn't post here.
Your stupidity lives forever!!! Muhahahahahahahahahhah!
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Me too. I tied up a broken CV shaft so it wouldnt drag, and ended up tearing out my entire throttle linkage. Stupid! Stupid! Stupid!
