Weird headlight behavior
I think my headlight/turn switch is acting up but any input on other culprits are welcome before I take the steering wheel off...
* When the light switch is off either parking light can be turned on by setting the turn switch left or right, respectively. * With the light switch in head light position the turn indicators work as the should but the headlights only shine in low, when I put the switch to high they go black. Am I right in thinking the headlight/turn switch is malfunctioning or could this be something else? Cheers, Björn
1980, 911 SC. Ex-US car in Sweden since June 2010. Insta: @911scowner |
Hi Björn:
My cousins spend about 5-6 month a year in Sweden. They ready enjoy your country. Quote:
You should also consider adding headlamps relays between the fuse panel and the headlamps to help reduce the current through the flasher switch. If you have a 1974 oir newer car, you can buy a kit here: Pelican Parts - Product Information: JWST-911-HLPR
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
+1 On All! Also: Fuse your dash lights, A/C condenser motor, footwell blowers, and evaporator relay.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 06-27-2010 at 04:35 PM.. |
Harry, nice to hear that your cousins enjoy Sweden, guess they are here in summer, 'cause the winter can be at bit long.
Great tip, I'm will try it asap. Sometime I will fit relays for sure, but at this point I need to focus on getting the car through inspection to get it properly registered here in Sweden so I can enjoy it over the summer (I just bought it from the UK). Cheers, Björn
Under the radar
![]() O.K. So why would one want one of their running lights on when they park their car? Like, half a parking light? This is not mentioned in the owner's manual.
For future reference I just wanted to post back and say that the work outlined in the thread Harry recommended did the job. Headlights now work as they should!
Cheers, Björn
Chris |
