another battery install thread
like most, when i got my 911 is had an older lead acid battery that had not been connected to a vent tube. luckily the battery tray was still solid so i just did some cleaning with baking soda and water then sponged it down and dried with my air compressor. i picked up a new kinetik hc800 agm battery (750cca), a box, a cutting board and some hardware and went to town.
old battery next to the new one. i am not exactly sure how much weight was saved but the new battery weighs just under 25lbs and looks to be less than half the size of the old one. ![]() ![]() here are the nuts i used to hold the battery box to the cutting board. not sure of the technical name but it's the same stuff we use to mount the plastic windshields on race cars. ![]() board is cut and box is mounted. ![]() ![]() next i drilled holes for the hold down. i used my 4" grinder to cut away a recess on the bottom for the brackets to sit into. ![]() ![]() battery in box and all together ![]() ![]() finally installed back into the car. the positive terminal i used had 2 8g set screws and a bolt on top. i snipped the ends of the 8g wires going to the battery and used the allen bolt holes. i connected the 4g line and the line for my amp to the bolt on top. snapped the plastic cover on, bolted the cutting board into the stock hole and all was right in the world.
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
Damn fine job, Kris!!!!
The cutting board is a cool idea. How did you keep the "nutserts" from spinning in the holes?
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Nice work. Where did you get that classy cover for the positive terminal?
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
thanks wayne. it was dumb luck, or maybe the slightly melted plastic around each hole from drilling, but they never moved once. i just started tightening down the screw from the top and never had a problem. Quote:
it is a battery terminal made by kinetik. there are literally hundreds of versions of terminals with almost countless combinations of set screw openings and ring terminal connections. ebay is a good place to see tha variety available, or sonic electronics. one of my favorites is made by a company called knu koncepts and uses a threaded insert to hold the wire in place. it is called the konfused terminal. they sell another style as well but i prefer the konfused due to it's range of available openings. in a situation like a 911 it would be overkill though. https://www.knukonceptz.com/productMaster.cfm?category=Battery%20Terminals these are the terminals i used. i got them as part of a package deal a while back in a car audio purchase i made. Kinetik HCNBC - Battery Terminals - Sonic Electronix i also bought "fancy" battery posts since they do not come with any when purchased new. (12.95) KINETIK KHC-TP (KHCTP) Power Top Post Silver Alloy Brass For Maximum Conductivity
Nice job. Looks great. Have to tell us how that battery has held up in a few years.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
Kinetik Battery Question
I'll second that you did a fantastic job putting this together.
I googled Kinetik to learn more about them. What is the difference in automobile starter applications and what Kinetik bill themselves for: Audio applications? I presume they work fine, but no reference to automobile applications. I couldn't find any reference to cold cranking amps in their literature. How were you able to determine 750 CCA for the HC800? I wonder what the HC600 has. Some guys are using a small Mazda Miata AGM battery by WestCo that delivers 450 CCA. This is all pretty confusing for me. I found on the Kinetik site the battery box, but couldn't locate the terminal covers. Great job and any further help would be appreciated. Tom |
there really isn't any difference, it's marketing. i got the specs here:
Audio Warehouse 1-800-388-8720
they are tiny. really tiny. i use one as a second battery in one of my cars and have not had a problem but i don't know if i would want to run it as my only battery. it is roughly half the size of the 800. i already linked the terminals and the posts in an earlier message.
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. Last edited by nineball; 07-03-2010 at 12:33 PM.. |
one year and ~3000 miles later and it still cranks up every time without a problem.
two years later and despite completely draining the battery twice (left the trunk open) and bringing it back to life with my battery tender it cranks up every time.
Great to hear its still holding up. Looked it up online found a lot of the parts. One more ? Do you keep it on a tender when not using car. What is the difference between a battery charger and a tender??
1986 Porsche 911 Targa 1983 911 sc 2015 WRX |
RETIRED
A tender is a low voltage only plugin that will shut off/on so as to maintain an optimal charge.
A battery charger goes from 2-10 amps and doesn't shut down and come back on again.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
as joe said a charger runs at full power all the time. a tender, also sometimes called a float charger, will only charge the battery when it is below a certain voltage (say under 11.5 or 12). once it is fully charged the tender turns itself off and monitors the battery charge level until it falls to the low point, then kicks on and restarts the cycle.
Took me awhile to get the parts and put it together but came out great thanks for info. Mine didn't come with the battery box.
very nice! one tip - get some washers to go on top of the rubber and under the wing nuts. you will be amazed at how much better the battery is held in place.
Nice how's this
Missed picture here itis
that's it. amazing the difference a couple of little pieces of metal can make.
I just finished mounting my Odyssey PC925 using some of the ideas here. Instead of grinding a small channel under the cutting board I drilled the holes, then counter sunk them from the bottom. Then I slid the bolt in there and heated it up with a torch just enough to melt the plastic of the cutting board. Then I pressed it into the bottom of the cutting board to make a custom fit and hold the bolt while the bracket is screwed on. I made a bracket out of some aluminum stock from the hardware store.
Before (notice the Gatorade bottle for the vent) ![]() Close up of the seated bolt, ![]() ![]() Finished unit before installation, ![]() Final job before connecting the terminals.
'84 Carrera (recently sold )'67 MB 250SL A few Italian motorcycles ......and a minivan for the crew Last edited by theclaw; 06-02-2013 at 01:19 PM.. |
Member 911 Anonymous
Nice, got my WestCo sitting ready for install, then re-corner balancing
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
nice install jeff.
i am happy to say that almost 3 years later after being drained twice, several de events, trips to out of state casinos, 3 trips to hershey and the east coast (philly, jersey, balitmore) and a few runs up to michigan all while powering my 5 channel alpine pdx amp the battery still performs flawlessly.
