SCWDP911's Avatar
changed starter, but now no run
What a day,
changed starter, engine cranks and cranks but no firing off. Pulled a plug wire, got spark. Spells like I have gas going in.
All I have done is disconnect battery, determ starter/solenoid, remove and replace starter/solenoid, reconnect starter/solenoid, reconnect battery, crank...
What am I missing/ have I knocked something loose?
Shane
- 1984 928S
Old 07-03-2010, 08:07 PM
Shaun @ Tru6's Avatar
is the yellow wire on the right terminal?
Tru6 Restoration & Design
Old 07-03-2010, 08:21 PM
brads911sc's Avatar
Try putting the yellow wire on the other terminal?
Was there other wires hooked up with it? Some people have their MSD or other such things connected at the starter.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 07-03-2010, 08:23 PM
SCWDP911's Avatar
I tried swapping the yellow wires and no joy. I have a stock setup pretty much on ignition. I am going to crawl under there one more time with light and see fi I can spot anything obvious, maybe swap wires around one mroe time and make sure everything is good and tight.
One thing that puzzled me is that both times (meaning after I swapped the yellow wires the first time) the car would crank regardless but not start. Is this right? I mean the cranking on either way.
Shane
- 1984 928S
Old 07-03-2010, 08:27 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Shane, was there maybe a second yellow wire? I thought some of these pre-Motronic car had an electric injector that squirted while the car was cranking.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 07-03-2010, 08:32 PM
brads911sc's Avatar
it sounds like maybe you knocked a wire lose. The main engine wiring harness exits the tin right next to the starter. far fetched but crazy things happen... maybe a wire got pulled off a sensor or something back there?
Old 07-03-2010, 08:33 PM
brads911sc's Avatar
My 83 had two yellow wires... a fat one (about 10-12 guage) and a small one (14-16 guage). I thought i recall even a third wire (buts its been awhile). I can crawl under mine tomorrow am if it would be helpful.
Ingo
Old 07-03-2010, 08:34 PM
SCWDP911's Avatar
I am calling it a night. The two wires I have been swapping are the two yellow wires Brad described above. Car cranks but won't light off no matter how I land these two wires.
Sounds like I need to pull the sorry starter out and take a look for something loose in the wiring Brad mentioned. Hopefully it will be easy to find. I know the starter will come out a lot easier (there is my glass half full outlook for the day!). The threads on the mounting posts looked like they had never heard of anti-seize.
Shane
- 1984 928S
Old 07-03-2010, 08:45 PM
i once installed a 944 starter that cranked backwards.
206 637 4071
Old 07-03-2010, 09:39 PM
SCWDP911's Avatar
well my fan is turning CW when I crank it...
I noticed the few times I cranked it tonight that there was a definite fuel smell. Tomorrow morning I will pull the starter off and inspect the harness area really well.
Shane
- 1984 928S
Old 07-03-2010, 10:29 PM
SCWDP911's Avatar
a new day is here, may the starting stars be aligned...
Shane
- 1984 928S
Old 07-04-2010, 05:58 AM
brads911sc's Avatar
I went out and looked at mine. I have a big power coming from the front of the car. A big fat Red power that is going back to the engine compartment. They are connected together. I then have 2 yellow wires that are connected on the same place at the starter. They are both on a spade connector. I dont have a stock starter (I have a high torque) so hopefully its relevant to what you see.
Old 07-04-2010, 07:01 AM
SCWDP911's Avatar
Thanks Brad. That would make sense seeing that mine seems to have no effect as to which spade terminal has what yellow wire on it. I am thinking at this point I knocked something loose, just not sure what. Getting ready to pull the starter back out in a few minutes. Hopefully I can see something amiss. This job is becoming a blow to the wrenching ego.
Shane
- 1984 928S
Old 07-04-2010, 09:12 AM
brads911sc's Avatar
I hear you on that. Also check up front at the battery that you didnt knock a fuse or wire lose when disconnecting the battery...
Old 07-04-2010, 09:45 AM
SCWDP911's Avatar
Well, amazing how easy it is to remove starter now!
Bad news is that I am not seeing anything as far as cables or wires knocked loose. I did not actually see the engine harness Brad spoke of, so I am going back out to take another look at that. I looked at cables at battery and everything looked normal there. I know it has spark. And I can smell gas after cranking it. It seems like it is going to be one of those "slap yourself in the face" kind of things but I would like to start slapping soon.
Shane
- 1984 928S
Old 07-04-2010, 11:20 AM
Perhaps you blew a relay, is your fuel pump running? You said you can smell fuel, but you never know.
If the engine is turning and you got spark, then it could be fuel.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 07-04-2010, 11:41 AM
P.S. I know it's the fourth, but please be careful. No fireworks in the Garage.
Old 07-04-2010, 11:42 AM
dshepp806's Avatar
Make damned sure you've not dropped a fuse somewhere.
Otherwise, get some voltage measurements at the starter connection while cranking.
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 07-04-2010, 12:05 PM
SCWDP911's Avatar
So far the only thing I found loose was the throttle linkage got knocked off where it first connects in the engine bay. Reconnected. Can find nothing else loose.
Put everything back together and still no start. Pulled the snorkel off, turned key on, pulled up on the flapper... I hear something like a pump running, so I am assuming my fuel pump is getting juice. And as said before, I can definitely smell gas after a start attempt.
I can't believe this is happening. The only problems I have had out of the car have the hot start issues with the starter solenoid. I change that and now the cars dead. I'm a 911 loser...
Shane
- 1984 928S
Old 07-04-2010, 12:11 PM
SCWDP911's Avatar
Best,
Doyle
If it is cranking, would I not have proper voltage at the starter? I am asking this in honest sincerity.
Shane
- 1984 928S
Old 07-04-2010, 12:13 PM
