rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
What weather stipping do I have to replace to get rid of the wind noise in my coupe
It has gotten really noisy. I have replaced the window channels and sunroof seals. What else is there?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 07-07-2010, 05:53 PM
more than likely, you need to adjust the window frame and/or door latch.
Old 07-07-2010, 05:57 PM
rs6er's Avatar
I've been told that they are good.
John
Old 07-07-2010, 05:59 PM
check condition of front hood seal, and door seals then. Maybe there is a missing fresh air duct in the front compartment.
Old 07-07-2010, 06:13 PM
Oh Haha's Avatar
Door seals make a HUUUUUGE difference if they are original or in bad shape.
I've replaced every seal associated with the driver's door but still have some wind noise at speed. I've given up chasing it. It's part of the charm now.
I have all of the factory door plugs in place as well.
The mirrors are known to be noise makers. Fold them in and take a short drive to see the difference.
While your door latch may be in good shape, pulling the door in a bit more will help it seal better.
Pacific Blue
Wayne
Old 07-07-2010, 06:18 PM
rs6er's Avatar
Which seal is the door seal— The little plastic one? If not, what part no.?
John
Old 07-07-2010, 06:34 PM
Oh Haha's Avatar
Originally Posted by rs6er View Post
which seal is the door seal— the little plastic one? If not, what part no.?
911-531-095-02-m260--large seal that goes around the door opening
911-542-403-01-M260--velvet seal that attaches to the body at the top of the door opening--tiny,tiny screws used for mounting
Pacific Blue
Wayne
Old 07-07-2010, 06:41 PM
I get a lot of noise that sounds like its from the wind going over the windshield at the edges. New door seals helped some noise but still really annoyed by noise from windshield
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 07-07-2010, 08:19 PM
Mitch Leland's Avatar
John,
As mentioned the door seals are a big one, our hosts carry them, they'll dress up your car, one P/N fits both sides. A fresh "factory" windshield gasket will make a giant difference as well. I cleaned out the gasket channel of all the previous sealant that shouldn't have been there anyway. Now the gasket lies/lays tight against the sheet metal and I have noticeably less wind noise in the cabin.
You have to go after each and every piece of this, and still it won't be perfect... but we try!
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 07-07-2010, 08:36 PM
Banned
While your hearing it, just put your finger around where you think the air is coming in. You'll be able to tell where you need to tighten it up.
As you press on different areas where you think the air is coming in, the pressure from your finger will either change the sound or stop the noise.
I put new door seals in my car and it did make a difference but there is one area by the 'wind wing' that air still gets in. If I press my finger against the seal in that area, it stops. I did notice that when I took the old seal out, there were little shims that I guess helped make the fit tighter.
I didn't put any shims back in, and that is why it probably makes noise.
The shims didn't look like anything professional. Just little slivers of wood.
Remember these cars are handmade and there are lots of little tweaks that are necessary.
Good luck.
Old 07-07-2010, 08:48 PM
There could be an "advanced class" probably taught in school on adjusting the door, window glass, window frame, and door latch.
I would suggest that properly adjusted doors and window frames will, when combined with new door seals, almost completely eliminate wind noise. When you drive a time capsule 911, you see what I mean.
I've thought about taking my 911 to a body shop simply to have the doors and window frame adjusted. But I'm afraid of the look I'd get when I explain that's all I want done.
Old 07-07-2010, 08:57 PM
Try driving a vent window '68 with dry rotted rubber. Less noise with vent windows slightly cracked open than when totally shut!
Face it, a 911 is not a new BMW in NVH development!
Old 07-07-2010, 10:04 PM
