You should leave your cars stock, if they have a good Bosch CDI. The MSD
and all the klug add-ons are a total waste. Plus, they make a good Porsche look like a high school autoshop project. Read the many posts about the MSD on this board over the last few months. The multiple spark system at low RPMs is a marketing gimimck. Check out this website (systemsc.com) on the Technical page under Ignition Systems for some additional info. Have Fun Loren '88 3.2
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
Thanks!!! Sprint. |
I love you guys...
MSD Schwepco. And don't let anybody disagree! |
For those that want to look at the numbers and see why the MSD has no
real added benefit: An engine at an idle of 1000 RPMs equals; 1. 16.7 revs per second or, 2. 60 ms (milleseconds) per rev for 360 degrees or, 3. 1 ms equals 6 degrees of engine rotation. The power stroke is 90 degrees. Since MSD ignition pulses can only be produced at a maximum of every 2 - 2.5 ms, the piston will have moved 12 to 15 degrees after the first spark occurs. How much real benefit is there for this late of an additional spark? The obvious lack of benefit becomes more real as the RPMs increase. For those that have doubts, use an o-scope and view the ignition pulses at the coil on the MSD system. Have Fun Loren '88 3.2
Thanks. Sprint. |
Loren;
Trust me, the ignition requirements of the older cars are different then the later EFI'd cars like yours. Your car has accurate fuel delivery across the board, especially at idle and that is considerably more difficult to achieve with the earlier cars. Most of our cars also have considerably more overlap then your car, which makes the balancing act even more difficult. I can tell you for a fact that the installation of the MSD onto my '69E (with 9.9:1 S pistons) made a very noticable improvement in the idle and low RPM running around town. While the second spark is 12 degrees after the first, keep in mind that our pistons have significant domes in which intrude into the cumbustion chambers. In a nutshell, the combustion quality at low rev's (when off-cam) is pretty bad and the multiple sparks are effective. Basically rather then a cylinder mis-firing due to the spark not igniting the mixture, it now fires 12 degrees retarded which is a lot better then nothing. With a modern engine with a better optimised cumbustion chamber, I agree that an MSD won't provide much benefit. If you're ever out in the Boston area, let me know and I'll show you.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman Last edited by jluetjen; 10-22-2003 at 11:01 AM.. |
Typo correction: The power stroke is 180 degrees and not 90 degrees.
The effect of additional spark pulses would be like retarding the engine 12 to 15 degrees with an extremely lean mixture at idle. The MSD does make an improvement over a points & coil ignition, but not the Bosch CDI. Sorry for the error. Loren '88 3.2
A good test for how effective the MSD is in firing a very rich mixture
would be to use a gas analyzer. You could measure the HC (hydrocarbons), a measure of unburned fuel, with a Bosch and then with the MSD. If the multiple sparks are effective, the HCs should be reduced. Good Luck Loren '88 3.2
Loren,
What should SprintStar do, as he currently has nothing - 30 year old Bosch or new MSD (for less $$$) You know we've been down this path before. Cam
1975 911S (in bits) 1969 911T (goes, but need fettling) 1973 BMW 2002tii (in bits, now with turbo) |
would be to use a gas analyzer. I dunno about whether it actually burns more fuel, but I watched my BMW idle at >10% CO for about 15 minutes with the MSD. It didn't foul the plugs.
"The power stroke is 90 (180) degrees. Since MSD ignition pulses can only be produced at a maximum of every 2 - 2.5 ms, the piston will have moved 12 to 15 degrees after the first spark occurs. How much real benefit is there for this late of an additional spark? The obvious lack of benefit becomes more real as the RPMs increase."
I'm slightly familiar with the ignition system used in MB's modular engines. If I remember, each of the twin plugs fires approx. 12 crankshaft degrees apart. In addition, they fire alternately on each power stroke; i.e. a-b, b-a, a-b, b-a, etc. Coincidently, this 12 deg. difference is the same spread you calculated for the MSD. My guesstimate is for emission purposes. Most, if not all of these ignition boxes, cease multiple sparking above ~3000 rpm. Sherwood http://members.rennlist.org/911pcars |
Installing a Crane HI-6 seemed to worsen my already poor idle due to a maladjusted mixture. I have no factual data since I don't know if it was too rich or too lean at the time, but there was a slight noticeable difference in the manner by which it surged. Since then, I've tuned my mixture and the motor purrs smoothly again.
Anyway, I switched to the aftermarket box b/c my original coil was on it's way out and the HI-6 was a cost effective way to remedy the situation while gaining a reliable rev limiter too. I tested the limiter by setting it to 4500 and pegging the needle. Interesting how there is no 'limit bounce' at all with the new box. Anyway, I like the security of that feature and no longer feel uneasy about those 20 year old 'go at any time' electronics.
Eugene (Formerly) at Pelican Parts Pelican's E-Commerce Guy, 2003-2011 2001 330i Sport 1983 911SC Coupe (sold) Last edited by Eugene at Pelican Parts; 10-22-2003 at 02:26 PM.. |
If you need a good Bosch CDI, call Tom Gould at Pelican.
He's still got some in stock. The M/B system is not a good comparision to the MSD, since it's a twin plug system and a different process is occurring. In response to my post about the pulse delay of 12 degrees, I assumed that the MSD could "recover" from the first spark in 2 to 2.5 ms. It might be much more or less. I doubt that they (MSD) have found the optimum delay for emissions. They just run their pulses at a max rate and the number is reduced as the RPM increases. Let's get those MSD and Bosch units on a gas analyzer! Have Fun Loren '88 3.2
15 981 GTS | 88 924S SE | 82 931 Holbert | 82 931 Rallye | 81 937 | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 80 US 931 | 80 931 GTR | 79 Sebring | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition | 77 Martini |
I had no choice in the matter really. My OEM ignition system would not fire reliably under boost at heavy loads. Once I installed the Crane HI-6 unit, I get reliable ignition performance, even at 1.25bar of boost. Couldn't be happier. It even allows me to run a larger than stock plug gap. Stock is 0.024", whilst I now run ~0.030"-0.032" with the Crane CDI unit
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Adding the MSD system helped the <3000 RPM running considerably. Basically it's less prone to a complete mis-fire which is what was causing the other issues. The 2nd or 3rd sparks, even though they are retarded compared to the initial spark help to ensure that the mixture gets lit off for each cylinder. Now a 924 2.0 is a completely differant animal and I would expect to not need the MSD. 1) The 924 has a Haron combustion chamber design where the head is flat and the combustion chamber is in a bowl of the piston -- similar to a diesel arrangement. This is quite different from the Hemi 911 head where the piston has a large dome sticking up into the head. In a 911 2.0 with a high-CR piston, the combustion chamber winds up being shaped like an upside down cereal bowl -- with a very long and contorted path to the edge of the combustion chamber, and poor squash performance. The 924 design on the other hand has a very compact combustion chamber design with the spark plug near the center and a good squash zone around the paremeter to promote turbulance in the combustion chamber. 2) I don't know what sort of cam profile you're running, but if you're still using the stock CIS injection system, chances are it doesn't have a lot of overlap to it. In situations where combustion chamber is compact and there isn't a lot of valve overlap, I really don't think that the MSD will get you much of an improvement since the combustion quality will generally be pretty good. When it comes to performance improvements, the Haron design gets good marks for chamber design, but suffers from poor thermal performance (getting combustion chamber heat out through the piston) and restricted valve size and duration. So I wouldn't bother with an MSD box in a 924 2.0.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman Last edited by jluetjen; 04-11-2007 at 06:08 AM.. |
I put an MSD 6A in my SC 3 years ago. The car has run well ever since, even with the CO set at about 3% (pulls better on the top end). The plugs last a year without any fouling problems. I do a full service (plugs, dizzy cap and rotor, filters and valve adjustment) once each 12 months. My car is not a garage queen, but is used as a daily driver. It always starts instantly in hot or cold weather and maintains a nice steady idle. It even gets pretty good fuel mileage!
So, let's see....starts well, runs strong, good mileage, no twiddling between tuneups. Oh yes, for the price of a REBUILT Bosch CDI I got a NEW MSD AND a set of Magnecor wires. And it was easy to install! Yep, I think the MSD is a keeper!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
