A/C compressor switch
Has anyone installed a separate A/C compressor switch in their 911? I would like to be able to use the evaporator fan to circulate air through the main dash vents without engaging the compressor. The fresh air system is basically useless in getting any reasonable airflow in the car. My Miata had a separate button that was pushed to engage the compressor and a rotating knob that varied the fan speed. Can that be done with our systems.
Old 07-22-2010, 11:44 AM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
bump, for an outstanding question. I would like to do something like this as well.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 07-29-2010, 01:47 PM
I did a simple cutoff switch for the compressor. Just put a toggle switch on one of the wires going to the compressor. When I flip that switch the compressor can't run. Then I can run the AC fan which blows right on me. It does not blow cold air but it blows.
The only time I use it is during autocross or DE sessions. I always run it at MAX fan speed.
Old 07-29-2010, 02:02 PM
Glen if you get a chance hit me back with some pictures.
Old 07-29-2010, 02:49 PM
If you turn the temperature switch fully CCW, it clicks and the compressor turns off.
Old 07-29-2010, 04:55 PM
kuehl's Avatar
You can splice the switch in either the green wire going to the thermostat switch or the green/white wire exiting the thermostat, or as Brian suggested you could play with having the thermostat set at one click to the right of the off position.
http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_82SC_AC.jpg
Old 07-29-2010, 06:55 PM
My thermostat switch has no clicks. It rotates smothly.
Old 07-29-2010, 07:24 PM
kuehl's Avatar
"Click" as in degree's. 12 o'clock is off. Turning CCW a few degree's.
Old 07-29-2010, 07:30 PM
