1970 911 RS clone Aerodynamics question
I just finished (as done as I can be this year) the suspension on my 70. I went with the Elephant racing coilovers in the front (350 lbs) and 31mm rear torsion bars. I have the Tarrett 25mm rsr sways front and rear. Not to bore you with the details almost every suspension component has been upgraded.
I took the car to the track and was really pleased with how neutral the car was. For me it was perfect. I want to focus on downforce now. My question is if I put a splitter on the front, what do I do to the ducktail to keep the downforce equal? I learned from my 1987 that if you do the front, you have to offset it in the rear. I am the blue car in the picture.
2007 GT3 Red, 2008 Cayman S Track Car, 1970 911T Tangerine, 2019 AMG E53 4, 2020 S450 2019 F350 King Ranch R Gruppe Member #626 Last edited by minoclan; 07-19-2010 at 05:18 PM.. |
I have a front splitter (fairly mild one) and regular ducktail and it works well. I think with a low/firm suspension, the balance is not upset as much.
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods |
I don't think you'll need to do anything...at least, nothing a small sway bar adjustment can't fix depending on the track.
I've run my car with a few different splitters, and the car handled pretty much the same. Removing the duck...THAT made a difference! ![]()
Todd Doing business with leebparts? http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/555068-attn-leebparts-please-contact-me.html |
Do you have the duck tail on or off now? What is the difference in handling?
2007 GT3 Red, 2008 Cayman S Track Car, 1970 911T Tangerine, 2019 AMG E53 4, 2020 S450 2019 F350 King Ranch R Gruppe Member #626 |
I did one event with no duck, the small "Lightning" circuit at NJMP. The difference was instability under braking-particularly at initial application. I figured a little over 100 pounds of lift at the end of the front straight.
Everywhere else, including the ~80MPH 180 degree turn onto the front straight the car was the same as with the duck. The duck is back on these days!
Paul Frere's 911 book has a good analysis of the various aero options front/rear and the effect on lift. Love that metallic blue.
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html |
Max Sluiter
From Fere:
I believe "Ducktail" curves are measured with front spoiler and Bürzel installed together. ![]() ![]() ![]() ![]() ![]() ![]() ![]() 1970 C-series (no spoilers) Cd=0.408 ClF=0.190 ClR=0.264 1972 E-series (front "S" spoiler/airdam, standard engine lid) Cd=0.408 ClF=0.107 ClR=0.261 At 143mph, front lift reduced 40% from 83 to 46.5 kg. Rear lift was still 114 kg @ 143 mph. Carrera RS with Carrera RS with standard front air dam (with blocked-off oil cooler)standard front air dam (with blocked-off oil cooler) and rear Bürzeland flat engine lid Cd= 0.397 0.409 Clf= 0.0700.064 ClR= 0.0840.290 front lift @ 152 mph = 35 kg32 kg rear lift @ 152 mph = 42 kg145 kg Rear-end grip increased by 20% with both front air dam and Bürzel When a deeper front air dam was used, some front downforce was made but it caused a rocking moment which increased rear lift. The deeper air dam was only used with larger RSR whale tails.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance Last edited by Flieger; 07-20-2010 at 05:20 PM.. |
So, should I put the splitter on like Todd has?
Sure - mine is not too different and works great with ducktail...
