dtw dtw is offline
GAFB
Best/safest way to disable ignition on 3.2
Going to do a CR test on a 3.2 tomorrow - what is the best way to disable the ignition so I can safely turn the motor on the starter, with all the plugs out? Thanks!
Several BMWs
Old 07-30-2010, 06:45 PM
I like to pull the wire from the coil and unplug the injector harness off the left front of the engine located on the chassis.
Bruce
Old 07-30-2010, 07:14 PM
Immature Member
dentist90's Avatar
I believe if you unplug the DME relay (under driver's seat) you will not only disable ignition but the fuel pump as well.
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 07-30-2010, 08:14 PM
That right and the best way to do it,....
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 07-30-2010, 08:21 PM
dtw dtw is offline
GAFB
I knew y'all were going to say DME relay. Thanks gents!
Old 07-30-2010, 10:17 PM
