VCI Brake Install Question
I have added the spindle spacer to the spindle and I still have the rotor rubbing the lower arm. I have ground some steel away, but I do not want oweaken it too much any suggestions.
Rick T |
Navin Johnson
Are the struts stock or raised spindle (RSR)
You will have problems even with the spacer if you have RSR struts.... However you can grind quite a bit of the arm away to gain clearance...btdt
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
they are stock 79's. I will start grinding and raise the suspension up with a floor jack to check for clearence after each grinding. I just don't want to weaking the parts to the point of breaking on the road
Rick T |
Schleprock
I had the same problem on three cars I know of. Don't worry about too much grinding. All three of the cars have been track proven.
Kevin L '86 Carrera "Larry" |
Yep, same here, had to clearance the end of the A Arms a bit for Brembo GTP-Ls.
Rob 1980 SC - 2011 Tiguan - 2018 Tesla M3P |
The Elephant Racing Decambered Ball Joints will get you clearance. These move the strut and rotor about .2 inches outboard, relative to the control arm.
They are available from our host.
Chuck Moreland - elephantracing.com - vonnen.com |
You have to grind material away for this " upgrade " ? Not a very well thought out kit is it ? Sorry that just doesn't sound right.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Yeah, it might seem that way but the VCI parts are nicely made.
The Porsche A arm in comparison is kind of a sloppy steel stamping with extra material on the edge. Take a 1/2mm off or so and you're good to go.
Todd Doing business with leebparts? http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/555068-attn-leebparts-please-contact-me.html |
