jld jld is offline
2.7 to 3.2 conversion- gas line problems
I'm swaping a 3.2 for my tired 2.7 and have discovered that the fuel return line on the car has a male fitting end and so does the engine. The line off the fuel rail is rubber with a hose clamp that goes to a hard bracket [male end]. Nobody around here has any metric fuel fittings. Anyone bumped into this problem??
Old 08-03-2010, 10:18 AM
Keep in mind that it's only a return line, no pressure, so you should be able to rig something simple without fear of a fuel leak.
Old 08-03-2010, 12:03 PM
BoxsterGT's Avatar
Porsche Crest
Do you need something like this........................
but with Female fittings on both ends?
Len at Autosportengineering dot com
Old 08-03-2010, 12:17 PM
IROC's Avatar
+1. That's what I did - a simple barb fitting/hose clamp arrangement.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 08-03-2010, 12:18 PM
DW SD's Avatar
get a metric to barb conversion fitting from BAT Inc. As suggested, it is a low pressure line. I used 7mm black braided fuel hose with double hose clamps (NORMA) on both ends.
Doug
1971 RSR - interpretation
Old 08-03-2010, 01:04 PM
BoxsterGT's Avatar
Porsche Crest
I have the Porsche OE Female hose ends in stock..........
and they are inexpensive. About $5 per nipple and $4 per nut if you want to hose clamp a short section together.
Old 08-03-2010, 02:33 PM
jld jld is offline
Len.....thats exactly what I need. I know it is low pressure and the line from the fuel rail is attached via hose clamp but I hate cutting the line on the car. How expensive is the metal line setup with double female ends?
Old 08-03-2010, 08:14 PM
jld jld is offline
by the way....THANK YOU all for the input
j
Old 08-03-2010, 08:16 PM
