Engine no turn over after re-install
Very quick ideas to check please.
87 3.2L with G50 tranny.
Engine was out, repaired, valve timing done correctly, so engine turns over easy at that time.
installed plugs, flywheel, pressure plate, engine still turns over at that time.
Mated G50 tranny on the engine, installed engine in the car, started it up, but engine does not turn over at all. Stuck.
What are some things I need to check...
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 02-08-2013, 11:17 AM
faverymi's Avatar
I will throw an easy one.
Will it turn with a wrench in the front pulley?
Is the shifter connected to tranny? Possibly is in high gear?
Ring pinion - starter - solenoid properly aligned, working properly?
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 02-08-2013, 11:39 AM
Straight shooter
Lapkritis's Avatar
Dead battery?
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 02-08-2013, 12:07 PM
KTL KTL is offline
Schleprock
KTL's Avatar
The main starter hot lead? Watch out, that sucker is live if the battery is connected.
Kevin L
'86 Carrera "Larry"
Old 02-08-2013, 12:09 PM
Senior Advisor
James Brown's Avatar
ring gear on with the tone ring? happens all to many times. you can hear the starter engage but the starter motor does not turn the engine? is that correct? or do you hear the starter running but the engine is not turning. can you turn the engine by hand or rock the car with the trans in gear?
08 Cayenne Turbo
Old 02-08-2013, 01:03 PM
Did you put the clutch plate on backwards and jam it up in the guide tube? Did it turn once and then stop?
We had this happen on an RSA after an install.
Very difficult to get the trans back off. We had to have a mechanic come over with an air chisel, and hammer it free.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 02-08-2013, 01:06 PM
Well the engine is back out so we will see ... stay tuned.
Old 02-08-2013, 01:17 PM
Found problem. I replaced one of the oil galley plugs sitting behind the flywheel and the new plug sticks out just enoug to intefere with the flywheel. Grinding it off a bit solved the problem.
Now, on to why no oil pressure when turning over with the starter and DME off.
Old 02-08-2013, 07:52 PM
