ninelevenick's Avatar
Front End Alignment Confusion
Okay, maybe I haven't thought hard enough about this, but why is my steering wheel turned to the 1:30 position when I am going straight down the road? This is after replacing the control arm bushings. I did not mess with the tie rods, but I did remove the aluminum cross member. I lowered the front end a bit too.
Old 08-08-2010, 08:58 PM
PRO Motorsports
Tyson Schmidt's Avatar
You got the steering rack bolted back in a millimeter or two off from before. A small movement at the rack makes a big difference at the wheel.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 08-08-2010, 09:39 PM
Tyson,
Should I simply reposition the steering wheel and center it?
Old 08-08-2010, 09:44 PM
Plays with cars's Avatar
Control arm bushings, changed ride height, repositioned steering rack, ... Me thinks you should be considering an alignment. Depending on how much you lowered it your toe settings could be out of wack.
Mark B
'73 911S (long term ownership) '70 914-6 (long term project) '74 914-2.0 (sold)
Old 08-08-2010, 10:43 PM
Absolutely, the toe and camber are off due to new bushings and lowering the ride height, but it seems like I could center the steering wheel first and then fine tune toe by adjusting the tie rods. Is my understanding accurate, or am I off base?
Old 08-08-2010, 10:49 PM
Senior Advisor
James Brown's Avatar
If you get it aligned, they will center the wheel, or you could center it yourself and get an alignment sometime soon.
08 Cayenne Turbo
Old 08-08-2010, 11:10 PM
Do the alignment work, then center the steering wheel. Camber --> toe --> steering wheel.
Edit: yeah, what James said
Mark B
Old 08-08-2010, 11:12 PM
