			 Bandwidth AbUser
			Perhaps a moderator can combine all these threads and leave them on the Engine Rebuilding forum.
	Jim R.  |
			 www.ALBERTOBILLA.it
			Many thanks to everyone for your help ... and sorry if I wrote some time I opened color or more topics ...
	![]() I finally succeeded in setting up the car ... I depleted the screw pump up bringing more MFIs to lean after 4000rpm I unscrewed the screw in place of the thermostat so enriching all ... now is a bit fatter at 3000 rpm but it's ok ... thanks for all your advice seriously without it I could not ... now my car has 336hp at 8250rpm and 6850rpm 34kg/ma ... THANK YOU!  |
			 Max Sluiter
			Just so that I make sure I understand correctly, you leaned the main rack adjustment and then richened the thermostat screw?
	1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance  |
			 www.ALBERTOBILLA.it
			I will lean the setting up and then I have all enriched the MFI from the pin to replace the thermostat
			 www.ALBERTOBILLA.it
			Yes, I lean adjustment pin max and then I enriched the MFI from the pin to replace the thermostat
