Another AC Question easy one though
I've done a search and perhaps my phrase was too long, but came up with LOADS of threads. None of them seem to address what I'm in need of.
I am looking for the 'hose' which carries the cold air from the AC EVAP box to the passenger cabin. I called our host today and they didn't show this hose also. SO, does anyone have a part number, link, name, any info so that I can get this part on order. This is the last step in my efforts to get more CFM into the car. Once I have the holes fixed I hope to post a HOW-TO thread for the EVAP squirrel cage fan upgrade. Thanks much! |
I had the local ac man source a generic plastic kind. Sold it to me per meter length. They seem to have it by the rolls. It was oversized so a foam layer filler was used to make a good fit to the smallish porsche ducting that is welded in the bulk head. Way cheaper than getting Porsche ori. Sorry but I didn't answer ur question.
Manassas, VA
Many sizes, lengths, etc. depending on the model and year of your car.
Mark
1991 964 Polar Silver Metallic Turbo Coupe |
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
i got all of my "hoses through Aircraft Spruce, its called "scat" tubing
Look on-line for someone who does aftermarket A/C, like Nostalgic Air Parts. They sell 3 inch flexible duct by the foot.
3 Inch Flexible Duct Hose - Duct Hose sold by the foot
'87 Carrera, Granite Green, SW Chip, Dansk sport cat, Kuehl A/C |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
The part appears to have been discontinued. Find a used one, or go with the other posts. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Throw it on the ground!
Three options/ideas for you: (1) Aircraft Spruce SCAT Tubing. Just measured my spare evap box and the outlet is 3" OD with some stretch (closer to 3-1/8" if duct hose with not stretch a little) SCAT AIRCRAFT DUCTING from Aircraft Spruce ![]() (2) PVC coupler from Home Depot: $3.50 Neoprene Rubber PVC coupler with stainless compression clamp......discard the stiff compression clamp and reuse the orig hose clamps. The fit is a little tight, only about 1/4" overlap on each end, just enough to secure to the box and vent outlets with little excess. Part number is 3 No Hub Coupling U95-003 Jones Stephens Co. $3.94 ![]() Installed ![]() (3) Silicon tubing ![]() Silicon turbo hose shown in use here:
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
MARK,
That is brilliant! IMHO reply's like this make this board 'THE BEST' web forum on the net hands down! For you to take the time and post such a comprehensive, well thought out, and exacting reply is brilliant. You Sir are top in my book! This really makes doing this job a breeze. Now if I can get a break in the heat so I can do the work. VERY APPRECIATED, if you cannot tell. Thanks for taking the time to help a complete stranger! SCOTT |
The Porsche part number for the evaporator to cabin flex hose is called "air distribution tube" part number: 91157124001, the hose should cost no more than $9.00 also get two new clamps and a right angle hose tool. Don't fart around with aftermarket parts
The SCAT tubing from Aircraft Spruce will be the equivalent of an OEM replacement vs "farting around with aftermarket" solutions. If you will note from earlier comments contained in this thread, there may be an availability issue on the part from the host and dealership channels.
