yep, im slow in the head
wow i hope my 78' targa isnt that hefty.... def see what an 2nd scale says.....
1978 911sc Targa - CNC plasma/router cut parts, tig welding, sheet metal work, VAG-COM, LM-1. let me know if u need something |
abides.
My '84 targa is about 2800lbs with a full tank, not including me. I've given up on this weight reduction shtick... I can keep up with any of the newer NA 911s just fine on the street.
Graham 1984 Carrera Targa |
3.6L X
abides.
Obsess much?
MBruns for President
You know it - works on the Monty Python chicks ALL the time.,.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Well I took the spare tiire and jack out, weighed them - 38 pounds. So I took them out. If I go on a longer drive, i'll pop them back in. But don't need them for around town I guess.
Most scales like those at a landscape company don't need to show an accurate actual weight, just be accurate between two readings, drive the empty truck on, drive the full truck on, difference is the weight of the load. If you want an accurate weight you need to get your car weighed on a set of corner scales.
My 86 with a 96 3.6, fiberglass front and rear bumpers, sun roof bits removed, all the other stock stuff still in and roll bar added weighed 2807lbs when corner balanced, with a tank of gas.
Robert Currently Porsche less (but the wife has 2) |
My SC weighs 2720 without A/C. I expected a couple of hundred less. It does have a nice sound/nav/bluetooth system, but that can't weigh much.
It's 98% street, so I won't obsess. __________ 81 911 SC "The money pit" |
At times it amazes me when people say..."especially with my fiberglass parts". Lessee.... steel panels maybe 3 mm thick vs fiberglass of 1/4"-1/2" thickness, depending upon where measuresd and what the pieces are. Early Corvettes weren't exactly lightweight either. This is not see-thru "race" fiberglass you have there. Same with aluminim and steel rim wheels. Cast Aluminum is awfully thick compared to a pressed structural steel wheel.
Gotta look at all aspects of "weight". We spoke seats for a moment. My 85 stock power seats weigh an incredible 55 lbs each. 110 lbs for a set. Two shell-type buckets might weigh 14 lbs each for a nice total weight savings of 82 lbs. Steely spare with collapsable spare is pretty weighty too.....
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
That's darn light IMO. My Euro spec '76 Ferrari 308 is 2900lbs with a small amount of fuel. Short of removing a/c equipment and using lightweight seats, I can't see how to shave down a ton more weight. I have no idea how on earth Michelotto got these things down to 2300lbs let alone the k lbs you Porsche guys see regularly! Amazing
Does anyone know what the sunroof motor and all those bits weigh in at?
Chris |
83 911 Production Cab #10
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Navin Johnson
Yes some of the crappy glass is equally as heavy as the steel it replaces....
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
The motor and cables really don't weigh much, it's the sub-roof and panel that is the big weight. Cut that out and bond in a CF panel and it's a worthwhile savings.
Gary R. |
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Dicklague:
Of course....when the pieces are roughly the same thickness in steel and glass....notice I said.." depending upon where measured and what the pieces are" I doubt most replacement 'glass body parts for street use are made to original steel thickness, perhaps other than hood and deck lids.
Its not the size of the boat its the motion in the ocean!.
Is it not fair to say that many should concentrate on their driver skills before trying to lose weight to make them faster. I used to race bikes and many were so preoccupied with having the lightest of equipment and ignored a lack of conering ability or correct gearing or the extra 5 pounds they had from eating too much |
1980 911 SC
The way it sits its plenty quick to shred the local speed limit, but I drive it a lot less because its so dang hot and humid in the summer. when I get the time the A/C will be rebuilt with new components and put back in. It's really hard to look cool when your sitting at a traffic light and you have sweat pouring down your forhead.
Life's a Beach |
Thanks for the reply on the sunroof. I'll search out how it's done. End of hijack. Thanks guys.
Chris |
I seem to remember 40 something pounds for the sunrood, the panel and associated hardware.
it's really not the weight so much as it is the location - High and can have a bigger influence on the CG
