e p slick's Avatar
A/C load drags down idle - how to adjust?
A/C load drags down idle to stall range - how to adjust? I just added A/C to old 86 Carrera and am not entirely sure how to compensate for A/C load at idle. Car sometimes stalls with A/C on and quick lift off accelerator pedal. I have had simple CIS cars but now Motronic. Have read some slightly conflicting adjust procedures in Bentley and Bosch books and now ask if anyone can suggest simple fix. Appreciate any input.
EP Slick - Tucson
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 09-16-2010, 10:18 AM
T77911S's Avatar
the idle control valve should do it. check to see if it is sticking.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-16-2010, 10:23 AM
Hi Paul,
You'll need to do some detective work in the shop manuals, but you need the connection between the compressor clutch and the ECU.
This tells the ECU to raise the idle speed via the ISV when the compressor clutch is engaged.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-16-2010, 12:08 PM
e p slick's Avatar
Thanks everyone. Idle valve seems to work properly per suggested testing. I have apparently bypassed ECU circuit with auxiliary wire so Steve, your adivce is most likely what I needed to pursue solution.
Again, Thanks All
EPS
Old 09-16-2010, 12:55 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
EP Slick - Tucson
I'm working this identical issue with another P-member who works on DME's.
I went through all of the Bentley diagnostics, ICV, Idle switch, and still have the issue.
The idle is rock solid at 800 rpm's w/o A/C.
With A/C, the idle drops down to about 750, then oscillates
between 650-750 rpms.
Your DME needs 12v on pin #29 when you activate the A/C
(pages 970-49 and 970-28).
This will provide an increase in rpm's.
But first, perform the ICV/Idle position switch diagnostics.
Please let us know how things work out.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-16-2010, 01:08 PM
