72' 911S
Solid Core Wires?
Can anyone tell me if these are solid core wires?
![]() ![]() Thanks! |
I can't say for sure by the photo but a quick check with an ohm meter will. If the resistance measures "0" they're solid core. Resistor wires are around 8,000 ohms per foot. Rob
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Looks like solid core.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
72' 911S
So does anyone know what would happen if I used these wires with an MSD ignition and MSD coil?
Mark S
Solid core wires use resistor ends for suppression and will short out with the higher energy ignition. Carbon core wires are made for high engery ignition systems.
With carbon core ignition cables HEI rated and plugs gapped at 0.060". ![]() Stranded copper wires could never perform in these conditions. Cheers, Joe Last edited by stlrj; 09-19-2010 at 09:36 AM.. |
Resistor wires are recommended for late model vehicles to reduce EMI affecting the electronics. Sherwood |
I would also disagree with the gap of .060.
Steve W and others recommend a gap of .045 to .050. Quote:
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
