72' 911S
leadrsa729's Avatar
Send a message via Yahoo to leadrsa729
Solid Core Wires?
Can anyone tell me if these are solid core wires?
Thanks!
Old 09-18-2010, 09:31 AM
I can't say for sure by the photo but a quick check with an ohm meter will. If the resistance measures "0" they're solid core. Resistor wires are around 8,000 ohms per foot. Rob
Old 09-18-2010, 10:10 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Thanks!
Looks like solid core.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
72' 911S
leadrsa729's Avatar
So does anyone know what would happen if I used these wires with an MSD ignition and MSD coil?
Old 09-18-2010, 10:20 AM
Mark S
MSD's website states solid core wires "cannot" be used with their system .
Info is under 'installation section'.
Old 09-18-2010, 11:15 AM
Solid core wires use resistor ends for suppression and will short out with the higher energy ignition. Carbon core wires are made for high engery ignition systems.
With carbon core ignition cables HEI rated and plugs gapped at 0.060".
Stranded copper wires could never perform in these conditions.
Cheers,
Joe
Old 09-18-2010, 09:36 PM
Cheers,
Joe
Beg to differ. I've used stainless steel plug wires for 20+ years with an aftermarket ign. box with no leakage or open circuits. That's on a pre-electronic '69.
Resistor wires are recommended for late model vehicles to reduce EMI affecting the electronics.
Sherwood
Old 09-20-2010, 10:17 AM
brads911sc's Avatar
I would also disagree with the gap of .060.
Steve W and others recommend a gap of .045 to .050.
Cheers,
Joe
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 09-20-2010, 12:23 PM
