Banned but not out, yet..
RSBob's Avatar
Question How do I set-up a Hidden Kill Switch - 82SC?
Searched the interwebs and the best I saw was something about interrupting the power feed to the coil. Since I am a lazy b@$t@rd, I would prefer to have a discretely hidden, or in plain sight switch in the dash which will keep the car from starting without cutting the power to my presets (because lazy b@$t@rd$ don't like resetting presets).
Is there a way to cut into the fuse panel to either shut off power to the fuel pump or coil or something by putting an inline switch in the cabin? Since I am basically a moron, if you could be really basic it would be helpful - I.e. connect a 15 gage wire to the top pole of fuse 7 (blah blah), run your line into the cabin (I can put in the switch) and return the other side of the wire to back to the fuse panel, connecting it to the bottom of fuse 7 or whatever.
Much grass for helping out the helpless.
Last edited by RSBob; 07-06-2014 at 08:52 PM.. Reason: Reason? I don't need no stinkin' reason!
Old 07-06-2014, 08:50 PM
ROW '78 911 Targa
timmy2's Avatar
You could just put a 20 amp rated switch in series with the starter solenoid wire.
That way it won't even crank without it being on.
Yellow #12 wire coming out of the starter switch and/or in the frunk for another access point to the wire.
Can't get much easier.
Or, you could get really fancy and wire in a relay to kill both the starter solenoid and the fuel pump. (Not the lazy option)
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-06-2014, 10:06 PM
Je Ne Sais Quoi = Targa
Mikey83835's Avatar
After my V-dub Scirrocco was stolen years ago, (I know, locking the barn after the horse was gone) my mechanic rigged up a kill-switch, a rocker type under the dash. But what it did was to cut off power to the fuel pump, so the scumballs could hotwire 'til the cows come home and it would still not run, so, good idea,
'74 Targa lightweight widebody, 3.6 motor, big bars, Speedlines, Sold 2018,
'81 SC Targa with 3.2 spoilers, Webers, SSIs, 7&8X16 Fuchs, 911R style exhaust,
Had a '71 911S Targa in the 80's, miss it,
Had a '61 Roadster in the 70's, miss it also,
Old 07-06-2014, 10:15 PM
My friend has a classic Mercury Cougar and he purchased a hidden kill switch that is a fake cigarette lighter. It's wired to his fuel pump and when he gets out of the car, he simply depresses the cigarette lighter and the car won't start. When he returns, he pulls out the lighter and everything is normal.
I'll have to check with him where he got this.
Old 07-06-2014, 10:57 PM
OsoMoore's Avatar
An easy standin when parking somewhere suspect is to pull the fuel pump relay.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go!
Old 07-07-2014, 08:58 AM
Wer bremst verliert
JohnJL's Avatar
I've seen a variant of this done with a standard lighter and a relay. When you get out of the car you take the lighter with you (or toss it in the ash tray or door pocket etc) and it disables either the ignition or fuel pump. Hidden in plain sight and pretty cool.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 07-07-2014, 09:26 AM
I'm not sure it will work with the CDI on an SC, but grounding the tach signal wire has worked well for me in the past. I've always used wire of the same color and gauge and an OE connector to further disguise the installation. Hiding the switch under the carpet works well. I use a push on/push off switch. As it's difficult to pull the tach with the steering wheel in place, it's hard to see the installation. I've seen the lighter trick, and think it's also a viable solution.
The Cap'n
Old 07-07-2014, 09:52 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
I still like the old style dimmer switch operated by the left foot for a kill switch.
It's hidden...and best of all...even if the bad guys are watching you start the car...they don't see you "reaching" for the kill!
Bob
Bob Hutson
Old 07-07-2014, 12:13 PM
Jonny H's Avatar
Don't mess with the power feed to the coil. There's 300V @ 6 or so amps on there.
That's why your coil has a sticker with a picture of a crossed out DVM on it so the breakdown man doesn't fry himself!
I'd go for the fuel pump since the wiring is in the frunk...
Old 07-07-2014, 12:20 PM
Armed Bastard
djb25's Avatar
The MSD 6 al ignition unit comes set up for a disable/kill switch. The instructions include a wiring diagram and everything.
I haven't actually set it up for my car, but it is on my to-do list.
Of course.... That isn't going to help you if you don't have MSD.
Damion
'77 911S Turbo, EFI 2.7l, Carrera intake, Megasquirt 3 with MS3x, Fuel & Ignition
Old 07-07-2014, 12:45 PM
porwolf's Avatar
+1. To keep the Targa safe I pull the fuel pump relay, pull the ground cable from the battery and lock the trunk, even in the garage.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 07-07-2014, 01:39 PM
Troll Hunter
Nothing will beat a flatbed. That's how they steal them these days. Quick, easy, gone.
1978 SC Coupe, Gris Argent Metallic Silver
1988 FJ62 Blue/Gray
2020 M2 CS
Old 07-07-2014, 03:16 PM
Nick is correct. I've seen a lot of motorcycles stolen with wheel locks and a few high end theft proof cars. Only guess with the cars was a flat bed. It's quick and easy. Also looks more legit. People will think car was broken down and called for a tow. I work in insurance. Cars are found gutted and burned.
Old 07-07-2014, 05:09 PM
you just ground the magnetic input if you are using points or hall effect primary, oor use ground the white wire if you are using magnetic.......you could do the same with any modern CDI. Not an MSD exclusive.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 07-07-2014, 05:29 PM
can somebody post some instructions on how to wire the cigarette lighter kill switch?
Old 08-01-2014, 12:58 PM
porwolf's Avatar
Nothing may absolutely prevent towing, flatbed or crane type, but life can be made difficult for towers:
Keep car from getting towed - HOWikis
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 08-01-2014, 02:14 PM
An unobtrusive switch that interrupts either the starter line from the ignition switch, or the fuel pump relay, is a reasonable first line of defense, and super easy to do.
Or if you are more devious, commandeer the headlight washer switch - you will never miss it!
1982 911SC Wine Red Metallic
OMG I love this car!
Old 08-01-2014, 03:24 PM
82 SC's Avatar
I have a kill switch in my 82 from previous owner and it works but I am unsure of what it is actually killing. If I forget to turn it on i can still crank the motor but not fire. I think i hear the fuel pump turn on so I don't think its killing it. Could be coil i guess. Can't trace the wires to anything as they are pretty well hidden. oh well.
1982 SC "Spooky"
1961 VW Single cab truck
1966 VW Deluxe Hard top
Old 08-08-2014, 09:54 AM
I had one wired up to a fuse in the rear of the car. I've since removed it because it was just for testing purposes, but I believe it was tied to my MSD.
Eventually I'll wire another one up to my rear window switch. No need for it any longer.
Old 08-08-2014, 12:43 PM
RSBob's Avatar
Did follow the advice here and wired up a hidden switch which kills the fuel pump. It took about 45 min. Now my paranoia can take a breather until the flatbed or skyhook appears.
Old 08-08-2014, 01:28 PM
