Rec Counter under reading
Hi,
1983 911 SC 3.00, the rev counter is reading way too low, probably half what it should, it was working fine a few months ago, any ideas?
Many thanks Stephen
Old 10-03-2010, 09:35 AM
Just bumping this, any ideas anyone?
Old 06-28-2013, 02:38 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Holy smokes - three years almost between posts - you got some patience.
Not being a tachometer wizard, I would start with electrical connections. The CDI box feeds the tach.
Permatune has a nice web page detailing the 6 pin connections. Make sure the tach wire is well connected. Even unplugging and re-plugging the harness can do wonders for skanky connections.
Perma Tune High Performance Ignition Systems
Get into the luggage compartment and push out the clock - into the passenger cabin. Then push out the speedo and tach. I don't remember if you need to start them from the luggage compartment and then finish the pull out in the passenger compartment. I do remember if you get the clock out it facilitates removal of the other gauges.
Check all connections one at a time on the tach. Look for corrosion, etc. It has to be something simple
1981 911SC Targa
Old 06-28-2013, 03:04 PM
