Je Ne Sais Quoi = Targa
Mikey83835's Avatar
Alignment question
According to my '82 SC owners manual, camber should be straight up for the rear wheels and very slightly positive for the front wheels, most of the P-cars out there seem to using negative camber, at least for the rear, is the factory info obsolete, or the optimum for long tire life, or....?
'74 Targa lightweight widebody, 3.6 motor, big bars, Speedlines, Sold 2018,
'81 SC Targa with 3.2 spoilers, Webers, SSIs, 7&8X16 Fuchs, 911R style exhaust,
Had a '71 911S Targa in the 80's, miss it,
Had a '61 Roadster in the 70's, miss it also,
Old 10-05-2010, 05:17 PM
My vote is optimum tire life. also tires have improved alot in 30 yrs. I have alwqys run a little neg camber up front and about 1/2 deg more neg at the rear.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 10-05-2010, 05:22 PM
Wash. State
nesslar's Avatar
I'm not sure all drivers can tell the diff. on the street, the track is another story. Regardless, neg. camber at the rear will wear the tires; can't rotate, obviously, but if you drive only several thousand miles a year, you will have better handling, and new tires every five years+? Not too big a deal, I guess. I'm at -1 degree, and I see the wear...........but again, over 4 years plus, not a big thing. Once had a guy tell me that with "straight up" the car would feel, quoting here, "...squirrelly as Hell". I have to question that, for "normal" street driving.
Old 10-05-2010, 05:40 PM
PRO Motorsports
Tyson Schmidt's Avatar
That spec is for when the ride heights were raised in the U.S. to meet bumper height regulations. These cars also had a thick spacer between the upper strut mount, and the top of the strut dust cover.
For the normal ride height it was 0 degrees front, and -.5 rear.
Most cars are well below either of these ride heights, so it is usually impossible to achieve these settings at the usual ride heights. (In the front anyway. The rear has a greater range of adjustment.)
A more typical street setting is -.5 front, and -1.0 rear.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 10-05-2010, 05:45 PM
Tyson is spot-on.
You do NOT want positive camber on these cars otherwise you will become aquainted with your local bodyshop on a first-name basis.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-05-2010, 06:28 PM
Originally Posted by Steve@Rennsport View Post
Tyson is spot-on.
That's the first time I heard that factory settings were dangerous.
What other factory settings should we be concerned about?
Old 10-05-2010, 11:25 PM
Banned
Old 10-06-2010, 02:25 AM
gtihop's Avatar
Just to add to this, how about caster setting for the front for street use? 6 deg sound right?
1983 911 SC
2015 Volks GTI
1991 Volks GTI
2011 Nissan Juke
1992 Nissan NX 2000
Old 10-06-2010, 03:51 AM
Steve and Tyson are giving good advice.
I run an additional .2 to .4 neg camber front and rear for AX and track, no noticable odd wear for street driving.
Old 10-06-2010, 06:31 AM
Mikey83835's Avatar
Thanks for all the input guys, I have been a fan of negative camber since 356 days, but now I am also noticing in our host's book, "101 Projects for Your Porsche 911", on page 153, he states that the 911 camber should be "0" with a slight positive emphasis, about 1/6th of a degree,
Curious....
Old 10-06-2010, 01:07 PM
Max Sluiter
Flieger's Avatar
Really?
Old 10-06-2010, 01:24 PM
The factory spec calling for a slight pos camber is probably chosen to reduce what is called "camber thrust". This minimizes wander and following of ruts in the road. It may improve road manners but won,t produce max cornering force. That will improve with neg camber, at the expense of road manners in a straight line and tire mileage.
1995 993 coupe
2012 Boss 302
Old 10-06-2010, 04:12 PM
gtc gtc is offline
abides.
gtc's Avatar
With basically stock suspension I run settings that are close to what Tyson wrote. I generally get very even treadwear.
Graham
1984 Carrera Targa
Old 10-06-2010, 04:50 PM
Tyson is spot-on.
I don't think that tire wear was the issue when you mentioned being aquainted with your bodyshop.
Old 10-06-2010, 07:18 PM
