Highbeam/lowbeam malfunction
Have '86 930 with hi/lo beam issues. About a year ago every time I put turn signal on to turn headlights would go from low beam to high beam after straightening out. Put a new steering wheel in this year and while steering assembly apart checked the turn signal/ hi-low beam operation. Everything worked fine after repeated checks. Re-installed wheel and everything still was working fine (in garage setting). Drove car several times and upon going thru signaling/turning operation a number of times, the turn operation would put me into hi-beam mode. Very difficult getting back to low beam mode. What is wrong and how do I correct. Can email me at smarlow@nycap.rr.com and respond to this forum both if not an inconvenience. Appreciate any help with this pain in the butt problem. Thanks
Old 10-15-2010, 01:23 PM
DonMo's Avatar
Send a message via AIM to DonMo Send a message via Yahoo to DonMo
Easy fix, see this link for the fix.
DonMo
1984 911 Carrera Targa
3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip
Columbia, SC
"Go Hokies"
Old 10-15-2010, 01:29 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
There are several good posts on this subject.
You might want to do a search-Turn signal stalk.
Also, there is an excellent post on cleaning/adjusting the contacts.
Another thought is to install some headlight relays.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-15-2010, 01:31 PM
wwest's Avatar
In the future don't let the 2-3-4 year old play behind the stearing wheel....
Old 10-15-2010, 03:34 PM
