6 cylinder symphony
Need some help - replacement of targa window corner seal
I'm trying to replace the corner seals on my 84 911. The seal is this part:
Pelican Parts - Product Information: 911-542-065-41-M260
Anyone know how? It doesn't look possible without removing the entire corner window.
Please help.
Thanks,
Ken
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 10-17-2010, 02:03 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Please help.
Thanks,
Ken
Ken,
Not sure what you mean by corner seals.
If it is the vent window glass seal this might help.
Just took a look at our '86, and there are two small screws
on top of the vent window frame.
This might be a good place to start.
As far as the window frame removal,
that would be a lot more work.
The frame is held in with two bolts on the
outside of the door, and one inside the door.
These serve as height and horizontal adjustments.
Please check page(s) 640-1 of your Bentley.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-17-2010, 02:36 PM
mcaterino's Avatar
I did this recently while changing out all the vent window rubber. Not fun. I think it all has to come out, because the lower two holes are in the vertical between the vent window and the regular window. Not only that, but the lower part of the corner is held in by some very odd rivets, which most people, including me, have to improvise to replicate. I used pop rivets and some washers which did the job, but not perfectly. Be ready for a pretty big job.
If you decide to go for it I can give a more detailed description.
Mike
Michael Caterino
Clemson, SC
1970 tangerine (=Tiger Orange) 'T' targa
restoration: mk911.blogspot.com
Old 10-17-2010, 02:48 PM
5String
Yep, as far as I know, the window frame has to come out of the door to replace these. I gather that it's a whole lot of work - only gather, though, since I'm sufficiently intimidated by this to have not replaced mine, though they need it badly. And then there's the problem, noted above, of finding rivets that will work properly - and then, installing them. Yikes!
5String
Tell not a soul that you have seen me; breathe not a word of what I say....
The Northwest Files
Old 10-17-2010, 03:21 PM
6 cylinder symphony
Mike -
I'm very interested in the long, detailed repair. Pelican sells the rivets that go in the "lower" holes. I bought those too.
I am going to have to do this, as I ripped the passenger side one (thinking "Hah - big deal, I have the new one in my hand!").....
Thanks,
Ken
'84 3.2 Targa
'89 964 Coupe
Old 10-17-2010, 05:22 PM
You must take out the window frame and disassemble to do this properly.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 10-17-2010, 05:58 PM
The rivet has a head and a flattened side. I drilled the head side after punching a small divot to keep the drill bit from sliding off. I think I started with a 1/8th drill bit and went up one size until the rivet spun. then I took a small chisel and hammered the tip of the flattend side off. You just have to be careful not to open the hole in the frame. The rivets are copper and I ordered from our host along with the rubber tips. It is not really complicated , just tedious. Take your time and you'll be ok. The hard part is hammering the new rivet , and as I said my Porsche mechanic slid a buck into the channel and hammered the rivet flat. The rivets are copper so they are maleable but you must be careful to not nick the frame.
1991 C2 Turbo
Old 10-17-2010, 06:05 PM
