EARLY 901/01 ENGINE Block '64 dated
Hi,
Found an EARLY 901/01 ENGINE Block '64 dated....and 901/01...under that mark there's 504 stamped.....unfortunately no engine number yet.....possibly an early 1965 911 aluminium engine block????? and crankshaft.... Or could it be a 1964 block? ATB |
That engine serial would be 900604 and a fairly early 1965 engine. Count the dots around the year at let me know; that tells you the month, check each case half for the date since they may be the same or not. The 504 is the build #, so the 504th production engine built. What are the casting numbers on the side of the case; 901.101.10x.xx each side is different.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Where are all these old cases coming from?
Hi can't post the pics because they are a *.bmp file....
It appears 901/01 and underneath 501 or 504, it's difficult to see wether it's a 1 or a 4 But looking at it again I think it's 501 (like levi's :-)) One case half is 901.101.101.01 and underneath that is a circkeld H I think there are 11 dots surrounding the build year of 64 I bought it on a few pictures alone and it probably will be send in approx. a week's time... |
If 11/64 casting date, it should be a ’65 engine or spare part.
This should be interesting bit of Porsche history. Thanks for posting. Here is how to convert *.bmp to *.jpg or *.jpeg: How to post images (pictures) on Pelican Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Party Member
"Where are all these old cases coming from?"
Cold case file. Ha ha Ha ...
Gary 71 911T Miss Demeanor / 2013 Audi Q5 Hundeführer / 1995 993 Miss Adventure |
Hi Grady,
THKS for the converting program!This comes in handfull!! What car (number) or approx... would it have belonged to? Maybe someone is looking for that (region) engine... Here are the pics.... ![]() ![]() ![]()
What is surprising me is the case wasn’t sold with images of the engine number.
Correct me if I’m wrong, if the case is assigned a type number (901/01) shouldn’t it have an engine number? Dave (Pelican djpateman) reports the engine number would be 900604 – I assume based on the build sequence 501. If it is a spare-part case, shouldn’t it have no numbers other than the matching-halves numbers? If it was a spare part case, it is used and not NOS as it has oil pressure relief valve(s) and oil fittings installed - among other. Keep us informed when you get the case. Best, Grady
Hi,
Finally got my hands on the case, it's in very good nick inside and outside.... ![]() Here's the long awaited numbers.... *900601* 901/01 501 case halfs both 720 so matching case year 11/64 What car would it have belonged to? Anyone searching... Was wondering since I haven't got the rest got a spare 901/03 magnesium 2,0 Liter engine, engine with aluminium cylinders lying around. What can I use to complete the aluminium case and get a running engine?
