Porsche 911 SC, SAAB SPG
Blinker problem - 1982 SC
I'm having a strange blinker problem that I need a second opinion on.
With everything as it should be, when I hit the hazard switch, all car sidelights turn on, however there is no blinking. The tach lights are both off.
If I ground the blue/white wire (pin C of blink relay, and goes to both direction lights in the tach), then blinking starts and the tach lights work as expected.
If I pretend to turn left, the left car lights come on and then the RIGHT tach light comes on bright, but then dims. When the dimming occurs, the left tach light comes on as well. If I ground the blue/white wire, this goes away and everything works as it should.
The same is true when turning right. The left tach light comes on bright but then dims and then the right tach light comes on at the same time.
I've been studying the circuit diagram trying to understand how the relay is supposed to work. From doing tests it looks like both Pin 49A and Pin C "blink" with the relay. It seems that only Pin 49A is really supposed to "blink" and Pin C is supposed to stay ground. At least this is what my testing leads me to believe.
I would love second opinions on this. I have a hard time believing a brand new relay is broken, but stranger things have happened. I did check the part numbers and the relay does seem to be the right model.
Jeff C
Old 11-20-2010, 11:18 AM
Here's the quick reference for German terminal numbers.
Terminal Definition
IGNITION
1 Ignition coil, ignition distributor, low voltage
(Ignition distributor with two separate electrical circuits)
1a to ignition contact breaker I
1b to ignition contact breaker II
2 short-circuit terminal (magneto ignition)
4 Ignition coil, ignition distributor, high voltage
(ignition distributor with two separate electrical circuits)
4a from ignition coil I, terminal 4
4b from ignition coil II, terminal 4
15 Switched + downstream of battery
(output of ignition/driving switch)
15a Output at dropping resistor to ignition coil and starter
GLOW PLUG AND STARTER SWITCH
17 Start
19 Preheat
BATTERY
30 input from + battery terminal, direct
30a input from + terminal of battery II
(12/24 V series-parallel battery switch)
31 Return line to battery
- battery terminal or ground, direct
31b Return ine to negative battery terminal or ground, via switch
or relay (switched negative)
(12/24 V series-parallel battery)
31a Return line to - terminal of battery II
31c Return line to - terminal of battery I
ELECTRIC MOTORS
32 Return line
(Polarity reversal possible at terminals 32-33)
33 Main terminal connection
33a Self-parking switch-off
33b Shunt field
33f For second lower-speed range
33g For third lower-speed range
33h For fourth lower-speed range
33L Counterclockwise rotation
33R Clockwise rotation
STARTER
45 Separate starter relay, output; starter input (main current)
45a Output, starter I
Input, starters I and II (Two-starter parallel operation)
45b Output, starter II (Two-starter parallel operation)
48 Terminal on starter and on start-repeating relay for
monitoring starting procedure
TURN SIGNAL FLASHER
49 Input
49a Output
49b Output, second turn-signal circuit
49c Output, third turn-signal circuit
STARTER
50 Starter control (direct)
50a Output for starter control
(Series-parallel battery switch)
50b Starter control with parallel operation of two starters with
sequential control
50c Input at starting relay for starter I
(Starting relay for sequential control of the engagement
current during parallel operation of two starters)
50d Input at starting relay for starter I
50e Input, Start-locking relay
50f Output, Start-locking relay
50g Input, Start-repeating relay
50h Output, Start-repeating relay
ALTERNATOR
51 DC voltage at rectifier
51e DC voltage at rectifier with choke coil for daytime driving
TRAILER SIGNALS
52 Signals from trailer to towing vehicle, general
WIPER MOTOR
53 Wiper motor, input (+)
53a Wiper (+), self-parking switch-off
53b Wiper (shunt winding)
53c Electric windshield-washer pump
53e Wiper (brake winding)
53i Wiper motor with permanent magnet and third brush (for higher
speed)
TRAILER SIGNAL
54 For lamp combinations and trailer plug connections
TRAILER STOP LAMP
54g Pneumatic valve for additional retarding brake,
electromagnetically actuated
LIGHTING
55 Fog lamps
56 Headlamp
56a High beam, high-beam indicator lamp
56b Low beam
56d Headlamp-flasher contact
57 Side-marker lamp: motorcycles, mopeds.
Abroad also cars, trucks, etc.
57a Parking lamp
57L Parking lamp, left
57R Parking lamp, right
58 Side-marker lamps, tail lamps, license-plate lamps and
instrument-panel lamps
58b Tail-lamp changeover for single-axle tractors
58c Trailer plug-and-receptacle assembly for single-conductor
tail-lamp cable with fuse in trailer
58d Variable-intensity instrument-panel lamp, tail-lamp and
side-marker lamp
58L Side-marker lamp, left
58R Side-marker lamp, right; license-plate lamp
ALTERNATOR (magneto, generator)
59 AC voltage, output
Rectifier, input
59a Charging armature, output
59b Tail-lamp armature, output
59c Stop-lamp armature, output
61 Alternator charge-indicator lamp
TONE-SEQUENCE CONTROL DEVICE
71 Input
71a Output to horns 1 & 2, low
71b Output to horns 1 & 2, high
72 Alarm switch (rotating beacon)
INTERIOR
75 Radio, cigarette lighter
76 Speaker
77 Door-valve control
SWITCHES
----------(Break-contact and changeover switches)----------------------
81 Input
81a 1st output, break side
81b 2nd output, break side
----------(Make-contact switches)--------------------------------------
82 Input
82a 1st output
82b 2nd output
82z 1st input
82y 2nd input
----------(Multiple-position switches)---------------------------------
83 Input
83a Output, position 1
83b Output, position 2
83L Output, left-hand position
83R Output, right-hand position
CURRENT RELAY
84 Input, actuator and relay contact
84a Output, actuator
84b Output, relay contact
SWITCHING RELAY
85 Output, actuator (end of winding to ground or negative)
86 Start of winding
86a Start of winding or 1st winding
86b Winding tap or 2nd winding
----------(relay contact for break and changeover contacts)------------
87 Input
87a 1st output (break side)
87b 2nd output
87c 3rd output
87z 1st input
87y 2nd input
87x 3rd input
----------(Relay contact for make contact)-----------------------------
88 Input
----------(Relay contact for make and changeover contacts (make side))-
88a 1st output
88b 2nd output
88c 3rd output
88z 1st input
88y 2nd input
88x 3rd input
ALTERNATOR and VOLTAGE REGULATOR
GENERATOR and GENERATOR REGULATOR
B+ Battery positive
B- Battery negative
D+ Dynamo postive
D- Dynamo negative
DF Dynamo field
DF1 Dynamo field 1
DF2 Dynamo field 2
----------(Alternator with separate rectifier)--------------------------
J Excitation winding positive
K Excitation winding negative
Mp Center point terminal
U,V,W Alternator terminals
DIRECTION INDICATOR (turn-signal flasher)
C First indicator lamp
C0 Main terminal connection for separate indicator circuits
actuated by the turn-signal switch
C2 Second indicator lamp
C3 Third indicator lamp (e.g., when towing two trailers)
L Turn-signal lamps, left
R Turn-signal lamps, right
Old 11-20-2010, 01:23 PM
Looking at the diagram
Terminal 49 of the turn signal flasher gets switched power from term 15 if the HS is not activated and from battery power term 30 if activated.
Terminal 31 of the turn signal flasher is the ground
Termina 49a is the flasher output. If the HS is not activated it goes to the turn signal switch input 49a. Selecting a L or R signal sends the flasher output to either term 49L or 49R. From 49L and R the signal goes to the right and left exterior bulbs and right and left tachometer TS indicators respectively.
From the TS indicator bulbs in the tach the paths goes to terminal C
When the HS is activated several poles close giving the flasher battery power and the output 49a goes to R, L and the red light in the switch simultaneously.
R and L power the exterior bulbs and the instrument indicators that side respectively.
I'm guessing you changed the signal flasher. Do the turn signals work normally when the hazard switch is not activated? Did you use one with 4 terminals marked c, 31, 49 and 49a such as PN 914-618-303-11. I'm no expert on 82s but have you also checked the hazard flasher switch? What happens when you push in the hazard switch? Now what happens when you then activate left turn signal. What about right turn signal. I think that's the box with 8 terminals marked 15, 30, 31, 49, 49a, 58, R & L in the diagram. From the diagram posted it appears the left and right turn signal lights are isolated until the flasher switch is depressed and a failure in one of the several poles of that switch could cause this.
Old 11-20-2010, 02:11 PM
Thanks for the list. I will print that out and add it to my collection of documents!
Also thanks for the electrical walk through. It matches what I was thinking as well.
The blinkers were working fine until just recently. In my quest of trying to track down why the e-brake light was constantly on (which is now resolved), I think I blew up the old relay (I was jumpering it trying to figure out how it worked).
So I bought a new relay with the part # you mentioned. It does have 4 pins and they are labeled like the wiring diagram.
I can get both the hazards and directionals working by applying ground to pin C (Blue/White wire).
Without the added ground, neither the hazards nor the blinkers work. It also doesn't matter if I press the hazard switch and then try the directionals.
From my investigation, the blue/white wire is getting some voltage which is why the opposite tach light is dimly lit (They are connected by this one wire). This is also why the relay isn't clicking.
The Blue/white wire is getting power either from the relay, or I somehow melted some wires in the harness and it is now touching one of the other signal wires.
I'll have to look for this more closely tomorrow.
Jeff C
Old 11-20-2010, 08:39 PM
pull the relay and see if the blue/white is powered?
Old 11-20-2010, 08:51 PM
I just want to finish off this thread for future searching.
I puchased a new relay from Pelican and it does work different than the other new relay I got from another source. The Pelican relay was $40 more expensive, however it does work as required!
The only question I have now is when the hazards are on, should the two tach lights blink as well or stay dark?
Currently they stay dark when the hazard switch is pressed and each light works when the indicator is used.
I'm glad this strange problem is resolved!
Jeff C
Old 12-01-2010, 07:59 AM
I can't be sure if the system on my 73 is working properly but when the hazards are on, the two tach lights do not light. All other functions of the turn signals, hazards, and tach lights are correct, however. I was always under the impression that the tach lights should blink also but I had nothing to compare it to so, as everything else is okay, I let it go. I would love to find out the correct function as well.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 12-01-2010, 09:29 AM
HarryD's Avatar
Terminal Definition
IGNITION
17 Start
19 Preheat
BATTERY
ELECTRIC MOTORS
32 Return line
33b Shunt field
STARTER
TURN SIGNAL FLASHER
49 Input
49a Output
STARTER
sequential control
ALTERNATOR
TRAILER SIGNALS
WIPER MOTOR
speed)
TRAILER SIGNAL
TRAILER STOP LAMP
LIGHTING
55 Fog lamps
56 Headlamp
56b Low beam
57a Parking lamp
side-marker lamp
Rectifier, input
71 Input
INTERIOR
76 Speaker
SWITCHES
81 Input
82 Input
82a 1st output
82b 2nd output
82z 1st input
82y 2nd input
83 Input
CURRENT RELAY
SWITCHING RELAY
86 Start of winding
87 Input
87b 2nd output
87c 3rd output
87z 1st input
87y 2nd input
87x 3rd input
88 Input
88a 1st output
88b 2nd output
88c 3rd output
88z 1st input
88y 2nd input
88x 3rd input
B+ Battery positive
B- Battery negative
D+ Dynamo postive
D- Dynamo negative
DF Dynamo field
DF1 Dynamo field 1
DF2 Dynamo field 2
This is a great list. I had always wondered what the numbers meant. Thank you!
I hate to press my luck, but, by chance, do you also have the list of the standard wire color codes as well?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 12-01-2010, 08:44 PM
THe colors are contained in DIN 47002 but I can't find it online - probably because of the propietary nature of the info.
Color code as per DIN 47002 (for twin color cables, base color is underlined)
ws white
br brown
gn green
ge yellow
gr gray
rs pink
bl blue
rt red
sw black
vi violet
wsbr white-brown
wsgn white-green
wsgr white-yellow
wsbl white-blue
wsrt white-red
wssw white-black
brgn brown-green
brge brown-yellow
brbl brown-blue
brsw brown-black
gnge green-yellow
gnrt green-red
gnsw green-black
gebl yellow-blue
gert yellow-red
gesw yellow-black
grrt gray-red
grsw gray-black
rssw pink-black
rsvi pink-violet
blrt blue-red
rtsw red-black
virt violet-red
Old 12-01-2010, 09:46 PM
HiWind's Avatar
I shd say I have a RHD euro 964 C2 and seems the flasher is one difference between US & EU cars - likely due to regs?
But any ways ...
can anyone help with a pic or color map for the emergency flasher wires please?
I tried to take a pic of the wiring into the plastic plug/socket but messed up and didnt get one. This is the part # 964 612 535 00 and its used with the emergency flasher.
I have these wires and these numbers - now to work out which goes with which??
7 sockets need wires (of 8): 15 49 30 58L 58R 49a 58 31
7 wires;
black
brown
red
black & white
blk & yellow
blk & green
white w green rings
this is on a 964 C2 but I think parts are same as 944 etc... Many many thanks!
Matt
Old 01-05-2013, 01:24 PM
