Exhaust header size for a 3.0?
What is the appropriate exhaust size for headers on a 3.0L carbed (and will be in a 914)? 1/2, 5/8, 3/4?
Thanks.
DD summer/winter: 2000 Boxster S DD spring/fall: 914-6 w/ 3.0L SC Dual Webers (For Sale) http://imgur.com/a/k0Wtl - My 914-6 Build/Project Story |
Good question,...
![]() Header size selection is based on the engine's configuration. Variables such as cams, compression, intake system (carbs), all factor in the choice. With SC or 964 cams, you'd do best with 1.5" ones. Remember too, its the rest of the exhaust system that makes the biggest difference since these engines are much more sensitive than people know.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Thanks! Any other opinions, or is the 1.5" agreed upon? If I go larger since the 1/2s aren't as widely available, does it create any issues...or just a little less power or something?
For muffler, I plan on taking the one it is currently using on the 911.
Bump!
porsher
i'm not an expert but it sounds like you need a quick answer.
people who know have posted that a larger than recommended header dia will have a significant impact on low end performance. I would stick with the 1.5"
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
You'll be hard pressed to find better advice than that offered by Steve Weiner. Stick with 1-1/2"
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
Steve's right it's all dependent on the engine mods. My 81 3.0L has 40mm weber's, Dougherty GT2-102 cams, 9.5:1 pistons and European 1 1/2' headers, twin plug heads and make 245hp at the crank.
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
Thanks guys, will go with the 1.5". Nothing against Steve, I just like to have multiple opinions on big purchases!
Registered speed offender
At what point would a 3.0 benefit from 1 5/8" tubes?
10.5:1 cr? ITB's? particular cams?
If you keep looking back, you'll never move forward. http://forums.pelicanparts.com/paint-bodywork-discussion-forum/506621-project-911r-something.html |
I'm guessing only the highest lift/longest duration variety cams that would create a high reving, manic type racing motor?
Ok, time to clarify. Were you guys talking 1.5" ID or OD? I was about to place the order, but the header guy (who's been making em for 30+ years) says I need 1/2" ID, thus 5/8ths OD.
You will want to purchase the 1 1/2" ID headers.
+1 - 1 1/2 id.
Marv Evans '69 911E |
Ok that's what I thought, just wanted to make sure. Thanks!
