This is one for you mechanical engineer types
I'm watching racing on the speed channel and I'm curious -- what causes flaming out of the exhaust pipes
1978 911 3.0 fully rebuilt and for sale
Old 01-11-2003, 10:58 AM
Randy Webb's Avatar
hot, unburned fuel meeting O2 -- tuning for max power doesn't mean all the fuel gets burned.
Old 01-11-2003, 11:15 AM
Senior Member
Doug Zielke's Avatar
Unburned fuel igniting in the (hot) exhaust pipes.
This usually happens on the overrun. Motors with large amounts of cam overlap contribute to this phenomenon.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 01-11-2003, 11:17 AM
A Quiet Boom's Avatar
Dougs got it right in the case of Gasoline powered cars, Randy would be partially correct on NitroMethane and some Methanol cars. Actually the NitroMethane is still burning as it exits the pipes.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 01-11-2003, 01:18 PM
Kevin Stewart's Avatar
Running a msd will do this the msd's spak stays lite a bunch longer, and will happen when there is a Y pipe in the system, Kevin
Old 01-11-2003, 01:50 PM
Administrator
Jack Olsen's Avatar
It's most common on Turbos, but even an ordinary rev limiter will do it sometimes.
Old 01-11-2003, 02:02 PM
Old 01-11-2003, 02:08 PM
911 user
Milu's Avatar
fitting a sparkplug to your tailpipe connected to the battery with a switch in the cabin also helps flaming from the exhaust
Where once the giants walked now Mickey Mouse is king.
My other car is also a Porsche.
Old 01-11-2003, 02:27 PM
I'm told that when I lift at the end of the straight @ Thunderhill, my car shoots about 5' of flame out of each pipe. It also shoots flames on the dyno at the end of each test, when the tech lets up.
Old 01-11-2003, 02:50 PM
The reason it's most common on turbos is because the K-jetronic is not equiped with the fuel shut off on decel feature that motronic incorporates to prevent this from happening.
Cheers,
Joe
Old 01-12-2003, 08:25 AM
