This is one for you mechanical engineer types
I'm watching racing on the speed channel and I'm curious -- what causes flaming out of the exhaust pipes
1978 911 3.0 fully rebuilt and for sale |
hot, unburned fuel meeting O2 -- tuning for max power doesn't mean all the fuel gets burned.
Senior Member
Unburned fuel igniting in the (hot) exhaust pipes.
This usually happens on the overrun. Motors with large amounts of cam overlap contribute to this phenomenon.
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
Author of "101 Projects"
They have cool flame-throwers installed just for the cameras!
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Dougs got it right in the case of Gasoline powered cars, Randy would be partially correct on NitroMethane and some Methanol cars. Actually the NitroMethane is still burning as it exits the pipes.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com 1966 912 converted to 3.0 and IROC body SOLD unfortunately ![]() 1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity! |
Running a msd will do this the msd's spak stays lite a bunch longer, and will happen when there is a Y pipe in the system, Kevin
Administrator
It's most common on Turbos, but even an ordinary rev limiter will do it sometimes.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
911 user
fitting a sparkplug to your tailpipe connected to the battery with a switch in the cabin also helps flaming from the exhaust
Where once the giants walked now Mickey Mouse is king. My other car is also a Porsche. |
I'm told that when I lift at the end of the straight @ Thunderhill, my car shoots about 5' of flame out of each pipe. It also shoots flames on the dyno at the end of each test, when the tech lets up.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
The reason it's most common on turbos is because the K-jetronic is not equiped with the fuel shut off on decel feature that motronic incorporates to prevent this from happening.
Cheers, Joe |
