E3 spark plug
Noobie here. First time Porsche owner. 84 3.2. not sure when the last time plugs and wires have been changed so it's on my list of things to do. Heard some chatter about the E3 Diamond fire plug.
Anyone had any experience with these???
Old 12-18-2010, 08:03 PM
Senior Advisor
James Brown's Avatar
Bosh or NGK plain copper only, that's all you need. $3 dollar plugs outperform $12 ones 3X.
08 Cayenne Turbo
Old 12-18-2010, 08:23 PM
I hate freight charges
village idiot's Avatar
Send a message via Yahoo to village idiot
I have them in my Carrera right now. No appreciable gains..........
Tom
78 911SC SC to 73RS imposter SCWDP crew #50 and 51
1969 Camaro "The new project"
Old 12-18-2010, 09:34 PM
Best advice here, hands-down.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-18-2010, 11:08 PM
DanielDudley's Avatar
Yup. Turns out these cars like a big fat electrode that can burn off a lot of deposits and tolerate a wide heat range while maintaining temperature. Old school plugs do that, and were state of the art when our cars were made.
It's a match.
Old 12-19-2010, 05:12 AM
ratpiper71T's Avatar
When I first started learning to service and maintain cars(I'm still learning), I fell for these multiground electrode plugs marketing hype. I put them on a more than a few cars and had hesitation, stalling, and missing problems with every single one. In addition to having an electrode much smaller and recessed than normal plugs, the heat range of these is not accurate, from what I understand. Although I haven't used this specific brand, I would say one can expect the same results. They will create problems that will confuse your diagnosis of the engine's health. Much like oilbath filters of long ago> k and n now. There's a reason why the automotive industry switched to the now considered- run of the mill- plugs and air filters. They do their job better. Don't fall for the marketing hype, it sure is convincing and deceiving.
Old 12-19-2010, 08:10 AM
Thanks for the comments. Kinda fits into the "if it sounds to good etc.."
Old 12-19-2010, 03:46 PM
Friend of Warren
Go with NGK BPR6ES.
Kurt V
Old 12-19-2010, 04:56 PM
Flat Six
Flat Six's Avatar
Originally Posted by Rot 911 View Post
Go with NGK BPR6ES.
BPR6ES is standard for 3.2; you might even consider one heat range colder (BPR7ES), too considering you're in AZ. FWIW, I have NGK BPR6EY in my 85 3.2 (the Y refers to 'V' shaped center electrode, supposedly to enhance flame kernel). But otherwise same plug and am very happy. Either was $2.79 at my local Napa. I use a little copper (hi-heat) anti seize but opinions vary on that point.
HTH
Dale
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 12-19-2010, 06:01 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
zactly.
all that platinum, +4, splitfire, unobtanium coated stuff is all snake oil.
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 12-19-2010, 11:17 PM
Senior Advisor
And why is that? you would think spark plug companies know what works, you should see the Champion plug guide, 60 pages of great knowledge. It can only be a marketing ploy.
08 Cayenne Turbo
Old 12-20-2010, 12:01 AM
SCOTITUDE's Avatar
it is all marketing. A friend of mine who worked for Champion educated me years ago. He let me read all the research Champion did on their competitors. Every other available brand was tested. All the fancy stuff was BS. No advantage except to lighten your wallet. I just had an issue on another car in the shop where it was misfiring. When I pulled the plugs they were those platinum +4's. Well they weren't +4's any more. some where plus 2's and some were plus 0's. the little electrodes had fallen off. some had 2 left, some where all gone. Crap.
2008 E93 M3 DD
Old 12-20-2010, 12:09 AM
Flat Six
Flat Six's Avatar
Let's also remember, though, that while many of the physical dimensions of spark plugs haven't changed in the last 25 years, ignition and engine management systems have.
More precise engine management is possible with water cooling than air cooling, for example, and allows for additional inputs such as knock sensors not practical on 20+ year-old air-cooled cars. Add to that the fact that head and combustion chamber design has evolved to the point where access to spark plugs is so limited on some newer cars is darn near impossible to R&R. And manufacturers' desires to increase maintenance intervals by a wide margin (50K-60K miles before first plug change), so design and market demands have also driven plug design, primarily for longevity IMHO. That's why we see so much platinum, iridium, unobtanium, etc. in electrodes. Under these (more) tightly controlled and precise combustion conditions the smaller electrodes can be used for more miles compared to copper.
Just my opinion here, but copper Bosch and NGK have served many P-owners well; I think it's fair to say that a search will turn up more positive than negative about copper for air-cooled Porsches, and the opposite will likely be true for platinum, etc.
Happy holidays
Dale
Dale
Old 12-20-2010, 08:24 AM
Once you get a spark that doesn't get blown out you can't improve from that. The rest is simple combustion. You don't need a fancy match to light a cigarette. You just need a match. A clean plug coupled to a strong ignition system will provide a peak of power. A fancy plug will do no different.
Old 12-20-2010, 01:13 PM
should you run new technology spark plugs if you have a modern ignition unit (like an msd), or should i still use the old type copper ones?
thanks
scott
'80 911 sc
'96 Range Rover
Old 02-07-2011, 07:38 PM
Senior Advisor
Scott, don't make me tell you again, COPPER.
08 Cayenne Turbo
Old 02-08-2011, 12:37 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
I was in the parts store to buy plugs last week. There was a box set up that had a copper plug and an iridium plug. Pressing a button caused each plug to spark. The iridium plugs spark was much bigger than the copper. That has to be good. I bought the iridiums.
Chris
73 911 E
Old 02-08-2011, 05:53 AM
jmccam's Avatar
I have E3s in my 83sc and there is no appreciable gain. Doesn't run bad or hesitate but the cheaper plugs would have done the same.
Save your money and use the extra to buy some beer.
1983 Porsche 911 SC Coupe
"We will either find a way, or make one" - Hannibal
Old 02-08-2011, 06:12 AM
Chris
73 911 E
If they're anything like the platinums, they'll work great at first. Then, within some months you'll be posting your first 'Stalls at idle' or 'Strange missing' thread on the forums. No sweat, the wear of these plugs may not be clearly visible, but just have a set of tradicionales on hand to change and problem solved.
Old 02-08-2011, 06:16 AM
I put the E3 in my 95 tacoma 2.7L 4x4. The truck ran good for about a yr. Then it started to sputter. I change back to copper plugs and it runs great again. Old ignition systems like the simple copper plugs. I run copper in my 80sc and it runs great! However, I run the E3's in my newer corvette and I love them.....anyway my 2 cents
Old 02-08-2011, 09:50 AM
